Ensure that the Solaris OS on which you are installing Trusted Extensions supports the features of Trusted Extensions that you plan to use. Complete one of the two tasks that are described in the following task map.
Task |
For Instructions |
Prepare an existing or upgraded Solaris installation for Trusted Extensions. | |
Install the Solaris OS with Trusted Extensions features in mind. |
