Solaris Trusted Extensions Installation and Configuration for Solaris 10 11/06 and Solaris 10 8/07 Releases
ProcedureConfigure a Multilevel Port for the Sun Java System Directory Server
To work in Trusted Extensions, the server port of the Directory Server must be configured as a multilevel port (MLP) in the global zone.
  1. Start the Solaris Management Console.
    # /usr/sbin/smc &
  2. Select the This Computer (this-host: Scope=Files, Policy=TSOL) toolbox.
  3. Click System Configuration, then click Computers and Networks.
    You are prompted for your password.
  4. Type the appropriate password.
  5. Double-click Trusted Network Zones.
  6. Double-click the global zone.
  7. Add a multilevel port for the TCP protocol:
    1. Click Add for the Multilevel Ports for Zone's IP Addresses.
    2. Type 389 for the port number, and click OK.
  8. Add a multilevel port for the UDP protocol:
    2. Type 389 for the port number.
    3. Choose the udp protocol, and click OK.
  9. Click OK to save the settings.
  10. Update the kernel.
    # tnctl -fz /etc/security/tsol/tnzonecfg
