How to Switch to a Workspace at a Different
Label
To switch to an existing workspace, perform one of the following:
In Trusted CDE, click the workspace switch at that label.
Figure 3–10 Front Panel With Switches at Different Labels
In Trusted JDS, click the workspace panel on the panel display.
You are now in that labeled workspace.
Troubleshooting
If you are logged in to a single-level session, you must log out to
work at a different label. Then, log in at the desired label. If you are permitted,
you can also log in to a multilevel session.
