As discussed in Mandatory Access Control, all applications and files in Trusted Extensions have labels. Trusted Extensions displays labels in the following locations:
Window label stripes above the window title bar
Window icon label stripes under the minimized window
Window label indicator in the trusted stripe
Query window label indicator from the Trusted Path menu that displays the label of the window or icon that is specified by the pointer location
In Trusted JDS, the color of the panels indicate the label of the workspace.
Figure 4–1 shows how labels display on a Trusted CDE desktop. Figure 1–5 shows how labels display on a Trusted JDS desktop. The Query Window Label menu item can be used to display the label of a window. For an illustration, see Figure 3–5.
