Oracle Solaris Trusted Extensions User's Guide
Logging In Remotely to Trusted Extensions
Virtual Network Computing (vnc) provides a way for you to access a central Trusted Extensions system from your laptop or home computer. The administrator at your site must configure the Solaris Xvnc software to run on the Trusted Extensions server and the Solaris vnc software to run on the client systems. You can work at any label in your label range that is installed on the server.
ProcedureHow to Log In to a Remote Trusted Extensions Desktop
Before You Begin
Your administrator has completed How to Use Xvnc to Remotely Access a Trusted Extensions System in Oracle Solaris Trusted Extensions Administrator’s Procedures.
  1. In a terminal window, connect to the Xvnc server.
    Type the name of the server that your administrator has configured with Xvnc.
    % /usr/bin/vncviewer Xvnc-server
  2. Log in.
    Follow the procedures in Logging In to Trusted Extensions.
    You can now work on the Trusted Extensions desktop in the vnc viewer.
