After obtaining the credential and remote host label, an application can call label_to_str() to convert the label data structure into a string. The string form of the label data structure can be used by the application.
Note that in the Trusted Extensions printing service, the label is returned as a string. The get_peer_label() function returns the string that is obtained by calling label_to_str() on the m_label_t data structure. This string value is returned in the slabel parameter of the get_peer_label() function, char** slabel.
The following code excerpt shows how the label_to_str() function is used:
sl = ucred_getlabel(uc);
if (label_to_str(sl, &pslabel, M_INTERNAL, DEF_NAMES) != 0)
syslog(LOG_WARNING, "label_to_str(): %m");
ucred_free(uc);
if (pslabel != NULL) {
syslog(LOG_DEBUG, "get_peer_label(%d, %s): becomes %s",
fd, (*slabel ? *slabel : "NULL"), pslabel);
if (*slabel != NULL)
free(*slabel);
*slabel = strdup(pslabel);
See get_peer_label() Label-Aware Function to view the source of the entire get_peer_label() routine.
