Oracle Solaris Trusted Extensions Developer's Guide
Setting Window Polyinstantiation Information
Status XTSOLsetPolyInstInfo(Display *display, m_label_t sl, uid_t *uidp, int enabled);
The XTSOLsetPolyInstInfo() routine enables a client to obtain property information from a property at a different sensitivity label than the client. In the first call, you specify the desired sensitivity label and the user ID, and set the enabled property to True. Then, you call XTSOLgetPropAttributes(), XTSOLgetPropLabel(), or XTSOLgetPropUID(). To finish, you call the XTSOLsetPolyInstInfo() routine again with the enabled property set to False. See the XTSOLsetPolyInstInfo(3XTSOL) man page.
