By default, the label_encodings.simple file is installed as /etc/security/tsol/label_encodings:
ACCREDITATION RANGE: classification= public; only valid compartment combinations: public minimum clearance= needtoknow; minimum sensitivity label= public; minimum protect as classification= public; |
The ACCREDITATION RANGE definition restricts the user to the following label:
PUBLIC is defined as the only classification
PUBLIC is defined as the only valid compartment combination
NEEDTOKNOW is defined as the minimum clearance
PUBLIC is defined as the minimum sensitivity label
PUBLIC is defined as the minimum protect as classification
The Classifications section is illustrated in the following figure.
The compartments in the file are illustrated in the following figure.
