Oracle Solaris Trusted Extensions Label Administration
Planning the Classification Values in a Worksheet
The worksheet in the following table shows names and hierarchical values defined for the four classifications. Because the value 0 is reserved for the administrative ADMIN_LOW label, the value of the PUBLIC classification is set to 1. The values of the other classifications are set higher in ascending sensitivity.
Note –
The names of groups in the labels are specified later, as WORDS in the SENSITIVITY LABELS and CLEARANCES sections.
Table 6–2 Classifications Planner
name=
sname=/aname=
value=
initial compartments= bit numbers/WORD
PUBLIC
PUB
1
None
INTERNAL_USE_ONLY
IUO
4
None
NEED_TO_KNOW
NTK
5
None
REGISTERED
REG
6
None
