The Configurator presents the following options
when resizing your partition:
Accept proposal as-is
Base partition setup on this proposal
Create custom partition setup
Perform the following steps to resize a partition:
From the Installation Settings dialog, select Partitioning, select Base partition setup on this proposal option, then click on Next.
Highlight the partition that you want to resize, then click on Resize.
Use the slider to set how much space you want to allocate to your Windows partition and your Linux partition, then click OK.
The minimum allocation of space for Linux is 3024 MB.
Click on Next to save the partition table and return to the Installation Settings dialog.
