This chapter describes post-installation procedures that you can perform after you install the Java Desktop System Release 3 on Linux systems.
The Java System Update Service (Java SUS
enables you to perform the following actions:
Install software updates for your Java Desktop System.
Choose which updates to install from a list of available updates.
Specify which server to check for available updates.
To launch the Java SUS
application, choose Launch -> Applications ->Utilities ->Online Update.
Refer to the Java System Update Service User's Guide for more information. This guide is available on the accompanying software media, and at http://docs.sun.com.
Before you start to configure your Xorg Xserver, you need to know the following:
Type of keyboard, for example, Sun Type 6 UK.
Mouse device, for example, /dev/usb/hid1.
Graphics adapter, for example, the model of your graphics adapter and the amount of video RAM.
Specification of the monitor.
Use the YaST2 configuration tool for configuring the Xorg Xserver on Linux systems.
