Java Desktop System Release 3 Troubleshooting Guide
2.3 Email and Calendar
2.3.1 Incorrect Display of Imported Contacts
Platform
  • Solaris OS for x86 systems
  • Linux
Problem
Change Request Number: 5088514
After you import an LDAP Data Interchange Format file with several contacts, only some of the contacts are displayed in your contact folder.
This is a display problem only. Email and Calendar has imported all the contacts.
Solution
Restart Email and Calendar.
2.3.2 Change Authentication Type
Platform
  • Solaris OS for SPARC systems
  • Linux
Problem
Change Request Number: 6246543
After you change the authentication type for the incoming mail server, Email and Calendar might not work correctly.
Solution
2.3.3 Multiple Attachments
Platform
  • Linux
Problem
Change Request Number: 6260583
If you drag and drop email messages to a new email message body, the content of the new email message is corrupted.
Solution
Select the messages that you want to attach and choose Action -> Forward -> Attached or press Ctrl+J to send the message.
