An application that manages the transfer of data between a computer and a PDA.
Your visible Java Desktop System, including all panels, icons, applications, and the desktop background.
The desktop background lies behind all of the other components on the Java Desktop System.
An icon on your desktop background that you can use to open your files, folders, and applications.
A unique alphabetic identifier for a computer on a network.
A drawer is a sliding extension to a panel that you can open or close from a drawer icon.
To prepare storage media for use with a particular file system. When you format media, you overwrite any existing information on the media.
An application that uses the standard GNOME programming libraries.
For example, gedit text editor is a GNOME-compliant
application.
An operation in which information is transferred between a computer and a PDA.
Hot keys are keyboard shortcuts that start applications.
A unique numeric identifier for a computer on a network.
A keyboard shortcut is a key or combination of keys that provides an alternative to standard ways of performing an action.
A launcher starts a particular application, executes a command, or opens a file. A launcher can reside on a panel or in a menu.
A menubar is a bar at the top of an application window that contains the menus for the application.
A Multipurpose Internet Mail Extension (MIME) type identifies the format of a file. The MIME type enables applications to read the file. For example, an email application can use the image/png MIME type to detect that a Portable Networks Graphic (PNG) file is attached to an email.
To make a file system available for access. When you mount a file system, the file system is attached as a subdirectory to your file system.
A pane is a subdivision of a window. For example, the file browser window contains a side pane and a view pane.
A panel application is a small, interactive application that
resides within a panel, for example the CD Player.
Personal Digital Assistant. A hand-held computer that you can use as a personal organizer.
A background application which waits for a PDA to attempt to synchronize with your computer. When a PDA attempts to synchronize with the computer, the PDA daemon synchronizes the data on the PDA with data on the computer.
A dedicated software tool that controls a particular part of the behavior of the Java Desktop System.
Shortcut keys are keystrokes that provide a quick way to perform an action.
A statusbar is a bar at the bottom of a window that provides information about the current state of what you are viewing in the window.
A special type of file that points to another file or folder. When you perform an action on a symbolic link, the action is performed on the file or folder to which the symbolic link points.
To merge data between a PDA and a computer.
A toolbar is a bar that contains buttons for the most commonly-used commands in an application. Typically, a toolbar appears under a menubar.
A Uniform Resource Identifier (URI) is a string that identifies a particular location in a file system or on the Web. For example, the address of a web page is a URI.
A Uniform Resource Locator (URL) is the address of a particular location on the Web.
A file manager component that enables you to display a folder in a particular way. For example, the file manager contains an icon view which enables you to display the contents of a folder as icons. The file manager also contains a list view which enables you to display the contents of a folder as a list.
A file browser window component that enables you to display a particular type of file in the view pane. A viewer component might add menu items that are relevant to the file type to the file manager menus. A viewer component might also enable you to use the file browser window zoom buttons to change the size of the item in the view pane.
A workspace is a discrete area in the desktop in which you can work.
