To modify how PDAs connect to your computer, perform the following steps:
Click Launch, then choose Preferences -> Desktop Preferences -> PDA Devices to start the PDA Devices preference tool.
In the Devices tabbed section on the Pilot Settings dialog, select the hardware settings that you want to modify, then click Edit.
Enter hardware settings for the PDA in the Device Settings dialog. For more information about the elements in the Device Settings dialog, see To Use an Assistant.
