Java Desktop System Release 3 User Guide
Choosing Default Fonts
To access the Fonts preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Fonts.
Use the Fonts preference tool to select the fonts to use in your applications, windows, terminals, and desktop background. For more information about selecting a font, see To Select a Font.
Table 7–9 lists the font preferences that you can modify.
Table 7–9 Font Preferences
Dialog Element
Description
Application font
Click on the font selector button to select a font to use in your applications.
Desktop font
Click on the font selector button to select a font to use on your desktop background only.
Window title font
Click on the font selector button to select a font to use in the titlebars of your windows.
Terminal font
Click on the font selector button to select a font to use in the Terminal application.
Font Rendering
To specify how to render fonts on your screen, select one of the following options:
  • Monochrome: Renders fonts in black and white only. The edges of characters might appear jagged in some cases because the characters are not antialiased. Antialiasing is an effect that is applied to the edges of characters to make the characters look smoother.
  • Best shapes: Antialiases fonts where possible. Use this option for standard Cathode Ray Tube (CRT) monitors.
  • Best contrast: Adjusts fonts to give the sharpest possible contrast, and also antialiases fonts, so that characters have smooth edges. This option might enhance the accessibility of the Java Desktop System for users with visual impairments.
  • Subpixel smoothing (LCDs): Uses techniques that exploit the shape of individual Liquid Crystal Display (LCD) pixels to render fonts smoothly. Use this option for LCD or flat-screen displays.
Details
Click on this button to specify further details of how to render fonts on your screen.
  • Resolution (dots per inch): Use the spin box to specify the resolution to use when your screen renders fonts.
  • Smoothing: Select one of the options to specify how to antialias fonts.
  • Hinting: Hinting is a font-rendering technique that improves the quality of fonts at small sizes and at low screen resolutions. Select one of the options to specify how to apply hinting to your fonts.
  • Subpixel order: Select one of the options to specify the subpixel color order for your fonts. Use this option for LCD or flat-screen displays.
Click on the Go to font folder button to display the Fonts file browser. Click Close to return to the Font Preferences dialog.
