Java Desktop System Release 3 User Guide
Display Modes Preferences
Use the Display Modes tabbed section to set display mode preferences.
Table 7–36 lists the display mode preferences that you can modify.
Table 7–36 Screensaver Display Mode Preferences
Dialog Element
Description
Mode
Use the drop-down list to specify the behavior of the screensaver application. Select from the following options:
  • Disable Screen Saver: Select this option if you do not want to use the screensaver application.
  • Blank Screen Only: Select this option if you want your screen to become blank when your screen locks.
  • Only One Screen Saver: Select this option if you want to display a single screensaver display from the display list when your screen locks.
  • Random Screen Saver: Select this option if you want to display a random selection of screensaver displays from the screensaver display list when your screen locks.
Display list
Select the screensaver display that you require.
Blank After
Use the spin box to specify how long to wait after the last use of the mouse or keyboard, to activate the screensaver.
Cycle After
Use the spin box to specify how long to show a particular screensaver display before the next display.
Lock Screen After
Select this option if you want the screen to lock after the screensaver is activated. Use the spin box to specify the delay between the activation of the screensaver and when the screen locks.
Preview
Click on this button to preview the screensaver display that is selected in the screensaver display list. To stop the preview, press any key or click a mouse button.
Settings
Click on this button to display the options for the screensaver display that is selected in the screensaver display list.
