This chapter describes how to start and use the preference tools to customize the Java Desktop System.
You can start the preference tools in the following ways:
Click Launch, then choose Preferences. Choose the tool that you require from the submenus.
Double-click on the This Computer object on the desktop background. A file browser window opens at the This Computer location. Double-click on the Preferences object in the browser window to display your preference tools. Double-click on the tool that you require.
To access the Assistive Technology Support preference tool, click Launch, then choose Preferences -> Accessibility -> Assistive Technology Support.
Use the Assistive Technology Support preference
tool to enable assistive technologies in the Java Desktop System. You can
also use the Assistive Technology Support preference
tool to specify assistive technology applications to start automatically when
you log in.
Table 7–1 lists the assistive technology support preferences that you can modify.
Table 7–1 Assistive Technology Support Preferences|
Dialog Element |
Description |
Enable assistive technologies |
Select this option to enable assistive technologies in the Java Desktop System. |
Screenreader |
Select this option to start the |
Magnifier |
On-screen keyboard |
To access the Desktop Background preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Desktop Background.
You can customize the desktop background in the following ways:
Select a color for the desktop background. You can select a solid color, or create a gradient effect with two colors. A gradient effect is a visual effect where one color blends gradually into another color.
Select an image for the desktop background. The image is superimposed on the desktop background color. The desktop background color is visible if you select a transparent image, or if the image does not cover the entire desktop background.
You can also change the appearance of your desktop background from within the file manager.
Table 7–2 lists the desktop background preferences that you can modify.
Table 7–2 Desktop Background Preferences|
Dialog Element |
Description |
Desktop Wallpaper |
Choose an image to display on the desktop background. To choose an image, click on the Select picture button. An image selector dialog is displayed. Use the dialog to choose an image. When you choose an image, click OK. |
Style |
Use the drop-down list to specify how to display the image. Select one of the following options:
Add Wallpaper |
Click on Add Wallpaper to display the Add Wallpapers dialog. Choose the wallpaper that you want to appear as the background, then click OK. |
Remove |
Choose the Desktop Wallpaper that you want to remove, then click Remove. |
Desktop Colors |
Use the drop-down list to select one of the following options:
To access the CD Database Server preference tool, click Launch, then choose Preferences -> Desktop Preferences -> CD Database Server.
The CD Database Server preference tool enables
you to configure a CD database server that your system can query. A CD database
server contains information about CDs, such as the name of the artist, the
title, and the track list. When an application plays a CD, the application
can query the CD database server about the CD, then display the information.
Table 7–3 describes the
preferences in the CD Database Server preference
tool.
Dialog Element |
Description |
Send no information |
Select this option if you do not want to send any information to the CD database server. |
Send real information |
Select this option to send your name and hostname information to the CD database server. |
Send other information |
Select this option to send another name and hostname to the CD database server. Enter the name in the Name field. Enter the hostname in the Hostname field. |
FreeDB round robin server |
FreeDB is a CD database. The FreeDB round robin server is a load-sharing configuration of FreeDB servers. Select this option to access the FreeDB CD database from this server. |
Other FreeDB server |
Select this option to access the FreeDB CD database from another server. Select the server that you require from the server table. |
Update Server List |
Click on this button to update the list of available FreeDB servers in the server table. |
Other server |
Select this option to use another CD database server. Enter the name of the server on which the database resides in the Hostname field. Enter the port number on which you can access the database in the Port field. |
To access the CD Device Options preference tool, click Launch, then choose Preferences -> Desktop Preferences -> CD Device Options.
The CD Device Options preference tool enables
you to configure options for CD devices on your system. The CD Device
Options dialog enables you to configure options for the following:
Data Discs
Audio CDs
Blank CDs
DVDs (Video)
Table 7–4 describes the preferences in the CD Device Options preference tool.
Dialog Element |
Description |
Start auto-run program on newly mounted disc |
Select this option to automatically start the auto-run program on a newly-mounted data disc. |
Run command when audio CD is inserted |
Select this option to run a command when you insert a CD. Enter the command in the Command field. Alternatively, to choose a command that you entered previously, click the down arrow button, then choose the command. You can also use the Browse button to choose a command. |
Run command when blank CD is inserted |
Select this option to run a command when you insert a blank CD. Enter the command in the Command field. Alternatively, to choose a command that you entered previously, click the down arrow button, then choose the command. You can also use the Browse button to choose a command. |
Run command when DVD (video) is inserted |
Select this option to run a command when you insert a DVD. Enter the command in the Command field. Alternatively, to choose a command that you entered previously, click the down arrow button, then choose the command. You can also use the Browse button to choose a command. |
To access the File Associations preference tool, click Launch, then choose Preferences -> Desktop Preferences -> File Associations.
Use the File Associations preference tool
to configure the following:
You can specify how files of various types are displayed and edited. For example, you can specify an icon to represent a particular type of file. Also, you can specify that if a file is a plain text file, the file is launched in a text editor.
The file manager and other desktop applications check the contents of a file to determine the type of a file. If the first lines do not determine the type of the file, then the application checks the filename.
A Uniform Resource Identifier (URI) is a string that identifies a particular location in a file system or on the Web. For example, the web address of a web page is a URI. A service is a protocol or task that a URI requests. For example, the http://www.gnome.org URI requests the http service.
You can associate an application with a service, so that the application performs the task required by the service. For example, you can associate your preferred web browser with the http service.
Table 7–5 describes the preferences
in the File Associations preference tool.
Dialog Element |
Description |
Table |
To view the contents of a category of file types, click on the right arrow next to the category name. The category expands, and displays a description of each file type, and the file extension that is associated with the file type. To select a file type, click on the file type. |
Add File Type |
Click on this button to add a file type. For more information, see To Add a File Type. |
Add Service |
Click on this button to add a service. For more information, see To Add a Service. |
Edit |
To edit a file type, a service, or a file type category, select the item that you want to edit, then click Edit. |
Remove |
To remove a file type or a service, select the item that you want to remove, then click Remove. |
Perform the following steps:
Start the File Associations preference
tool.
Click on the Add File Type button.
Enter the properties of the file type in the Add File Type dialog.
The following table describes the dialog elements of the Add File Type dialog:
Dialog Element |
Description |
No Icon |
Choose an icon to represent the file type. To choose an icon, click on the No Icon button. An icon selector dialog is displayed. Choose an icon from the dialog. Alternatively, to choose an icon from another directory, click Browse. When you choose an icon, click OK. |
Description |
Enter a description of the file type. |
MIME type |
Enter the MIME type for this type of file. |
Category |
Enter the category to which you want the file type to belong in this preference tool. Click on Choose to choose a category from the Choose a file category dialog, then click OK. |
Filename extensions |
Enter the file extensions to associate with the file type. Enter a file extension in the field on the left side, then press Return. To remove a file extension, select the file extension in the field on the right side, then click on the Remove button. |
Viewer component |
Use the drop-down list to select the viewer component to display files of this type in the file manager. |
Default action |
Use the drop-down to select the default application to open files of this type. |
Program to run |
Specify a program to associate with the file type. Enter the command to start the program. Alternatively, to choose a command that you entered previously, click the down arrow button, then choose the command. You can also use the Browse button to choose a command. |
Run in Terminal |
Select this option to run the program in a terminal window. Choose this option for a program that does not create a window in which to run. |
Click OK.
tool.
Click on the Add Service button.
Enter the properties of the service in the Add Service dialog.
The following table describes the dialog elements on the Add Service dialog:
Dialog Element |
Description |
Description |
Enter a description of the service. |
Protocol |
Enter the protocol for the service. |
Program to Run |
Use the drop-down list to select a program to run for this service. |
Program |
Specify the program to associate with the service. Enter the command to start the program. Alternatively, to choose a command that you entered previously, click the down arrow button, then choose the command. You can also use the Browse button to choose a command. |
Run in Terminal |
Click OK.
You can customize your folders to suit your requirements and preferences. This section describes how to customize your folder preferences.
To access the Folders preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Folders.
Alternatively, you can use the File Management Preferences dialog to set preferences for the file manager. To display the File Management Preferences dialog, choose Edit -> Preferences from any file browser window.
You can set preferences in the following categories:
The default settings for views
The behavior of files and folders, executable text files, and Trash
The information that is displayed in icon captions
The order information that is displayed in list views
Preview options to improve the performance of the file manager
You can specify a default view, and select sort options and display options. You can also specify default settings for icon views, list views, and tree views. To specify your default view settings, click on the Views tab in the File Management Preferences dialog.
Table 7–6 lists the view preferences that you can modify.
Table 7–6 File Management View Preferences|
Dialog Element |
Description |
View new folders using |
Select the default view for folders. When you open a folder, the folder is displayed in the view that you select. |
Arrange items |
Select the characteristic by which you want to sort the items in folders that are displayed in this view. |
Sort folders before files |
Select this option to list folders before files when you sort the contents of a folder. |
Show hidden and backup files |
Select this option to display hidden files and backup files in the view pane. The first character in a hidden filename is a period (.). The last character in a backup filename is a tilde (~). You can hide files from the view pane by adding the .hidden extension to the filename. |
Default zoom level |
Use the drop-down list to select the default zoom level for folders that are displayed in the icon view and list view. The zoom level specifies the size of items in a view. |
Use compact layout |
Select this option to arrange the items in icon view so that the items in the folder are closer to each other. |
Text beside icons |
Select this option to place the icon captions for items beside the icon rather than under the icon. |
Show only folders |
Select this option to display only folders in the Tree in the side pane. |
To set behavior preferences for files and folders, click on the Behavior tab in the File Management Preferences dialog.
Table 7–7 lists the behavior preferences that you can modify for files and folders.
Table 7–7 File Management Behavior Preferences
An icon caption displays the name of a file or folder in an icon view. The icon caption also includes three additional items of information on the file or folder. The additional information is displayed after the file name. Normally only one item of information is visible, but when you zoom in on an icon, more of the information is displayed. You can modify what additional information is displayed in icon captions.
To set your preferences for icon captions in the File Management Preferences dialog, click on the Icon Caption tab.
Use the drop-down lists to select the items of information that you want to display in the icon caption. The following table describes the items of information that you can select from each drop-down list:
You can specify what information is displayed in list view in file manager windows. For example, you can specify which columns are displayed and the order in which the columns are displayed.
To set your preferences for list columns in the File Management dialog, click on the List Columns tab to display the List Columns tabbed section. To specify a column to display in list view, select the option that corresponds to the column, then click on the Show button. To remove a column from the list view, select the option that corresponds to the column, then click on the Hide button.
Use the Move Up and Move Down buttons to specify the position of columns in list view.
To use the default columns and column positions, click on the Use Default button.
The following table describes the columns that you can display:
The file manager includes some file preview features. The preview features can affect the speed with which the file manager responds to your requests. You can modify the behavior of some of these features to improve the speed of the file manager. For each preview preference, you can select one of the options described in the following table:
Option |
Description |
Always |
Performs the action for local files, and files on other file systems. |
Local Files Only |
Performs the action for local files only. |
Never |
Never performs the action. |
To set your preview preferences in the File Management Preferences dialog, click on the Preview tab.
Table 7–8 lists the preview preferences that you can modify.
Table 7–8 File Management Preview Preferences|
Dialog Element |
Description |
Show text in icons |
Use the drop-down list to specify when to preview the content of text files in the icon that represents the file. |
Show thumbnails |
Use the drop-down list to specify when to show thumbnails of image files. The file manager stores the thumbnail files for each folder in a .thumbnails directory that is one level below the folder. |
Only for files smaller than |
Use the drop-down list to specify the maximum file size for files for which the file manager creates a thumbnail. |
Preview sound files |
Use the drop-down list to select an option to specify when to preview sound files. |
Count number of items |
Use the drop-down list to specify when to show the number of items in folders. If you have set your view to icon view, you might need to increase your default zoom level in the Views tabbed section to see the number of items in each folder. |
The file manager includes backgrounds that you can use to change the look-and-feel of the following screen components:
Desktop
Side pane and view pane of file browser windows
Panels
To change the background of a screen component, perform the following steps:
From the file manager, choose Edit -> Backgrounds and Emblems.
To display a list of patterns that you can use on the background, click on the Patterns button in the Backgrounds and Emblems dialog. To display a list of the colors that you can use on the background, click on the Colors button. To add an emblem to an object, click on the Emblems button.
To change the background to a pattern, drag the pattern to the screen component. To change the background to a color, drag the color to the screen component. To add an emblem to a background object, drag the emblem to the object.
Click Close.
To reset the background of the view pane or side pane to the default background, right-click on the background of the pane, then choose Use Default Background.
When you change the background of the side pane or the view pane of a particular folder, the file manager remembers the background that you chose. The next time that you display the folder, the background that you selected is displayed. That is, when you change the background of a folder, you customize the folder to display the background.
To add a pattern to the patterns that you can use on your screen components, choose Edit -> Backgrounds and Emblems in a file manager window. Click on the Patterns button, then click on the Add a New Pattern button. A dialog is displayed. Use the dialog to select the new pattern. Click OK to add the new pattern to the Backgrounds and Emblems dialog.
To add a color to the colors that you can use on your screen components, choose Edit -> Backgrounds and Emblems in a file manager window. Click on the Colors button, then click on the Add a New Color button. A color selector dialog is displayed. Use the color wheel or the sliders to choose the color. Click OK to add the new color to the Backgrounds and Emblems dialog. For more information about selecting a color, see To Select a Color.
To add an emblem to an object, choose Edit -> Backgrounds and Emblems in a file manager window. Click on the Emblems button, then click on the Add a New Emblem button. For more information about adding a new emblem, see To Add a New Emblem.
To access the Fonts preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Fonts.
Use the Fonts preference tool to select the
fonts to use in your applications, windows, terminals, and desktop background.
For more information about selecting a font, see To Select a Font.
Table 7–9 lists the font preferences that you can modify.
Table 7–9 Font Preferences
To access the Input Method preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Input Methods.
Input Methods are software components that
enable you to enter characters other than printed characters on a keyboard. Input Methods are commonly used to enter text for languages
using thousands of different characters in keyboards with far fewer keys. Input Methods are mostly associated with languages such as Japanese,
Chinese, and Korean.
Use the Input Methods preference tool to
configure integral and multilingual input method capabilities.
Table 7–10 describes the elements on the Input Methods preference tool.
To access the Proxy Configuration preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Proxy Configuration.
The Proxy Configuration preference tool enables
you to configure how your system connects to the Internet. You can configure
the Java Desktop System to connect to a proxy server,
and specify the details of the proxy server. A proxy server is a server that
intercepts requests to another server, and fulfills the request itself, if
possible. You can enter the Domain Name Service (DNS) name or the Internet
Protocol (IP) address of the proxy server. A DNS name
is a unique alphabetic identifier for a computer on a network. An IP address is a unique numeric identifier for a computer on a
network.
Table 7–11 lists the proxy configuration preferences that you can modify.
Table 7–11 Proxy Configuration Preferences|
Dialog Element |
Description |
Direct internet connection |
Select this option if you want to connect directly to the Internet, without a proxy server. |
Manual proxy configuration |
Select this option if you want to connect to the Internet through a proxy server, and you want to configure the proxy server manually. |
HTTP proxy |
Enter the DNS name or the IP address of the proxy server to use when you request a HTTP service. Enter the port number of the HTTP service on the proxy server in the Port spin box. |
Details |
Click on the Details button to display the HTTP Proxy Details dialog. Select the Use authentication option to enable the Username and Password fields. Enter the username and password for the selected HTTP proxy server. Then click Close. |
Secure HTTP proxy |
Enter the DNS name, or the IP address of the proxy server to use when you request a Secure HTTP service. Enter the port number of the Secure HTTP service on the proxy server in the Port spin box. |
FTP proxy |
Enter the DNS name or the IP address of the proxy server to use when you request an FTP service. Enter the port number of the FTP service on the proxy server in the Port spin box. |
Socks host |
Enter the DNS name or the IP address of the Socks host to use. Enter the port number for the Socks protocol on the proxy server in the Port spin box. |
Automatic proxy configuration |
Select this option if you want to connect to the Internet through a proxy server, and you want to configure the proxy server automatically. |
Autoconfiguration URL |
Enter the URL that contains the information required to configure the proxy server automatically. |
To access the Keyboard accessibility preference tool, click Launch, then choose Preferences -> Accessibility -> Keyboard.
Use the Keyboard accessibility preference
tool to set the keyboard accessibility preferences. The Keyboard accessibility preference tool is also known as AccessX.
You can customize the preferences for keyboard accessibility in the following functional areas:
Basic
Filters
Mouse
Table 7–12 lists the basic keyboard accessibility preferences that you can modify.
Table 7–12 Basic Keyboard Accessibility Preferences
For more information about configuring basic keyboard accessibility preferences, see the Java Desktop System Release 3 Accessibility Guide.
Table 7–13 lists the keyboard accessibility filter preferences that you can modify.
Table 7–13 Keyboard Accessibility Filter Preferences
For more information about configuring filter accessibility preferences, see the Java Desktop System Release 3 Accessibility Guide.
Table 7–14 lists the mouse accessibility preferences that you can modify.
Table 7–14 Mouse Accessibility Preferences
For more information about configuring the mouse accessibility preferences, see the Java Desktop System Release 3 Accessibility Guide.
To access the Keyboard Behavior preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Keyboard -> Behavior.
Use the Keyboard Behavior preference tool
to modify the autorepeat preferences for your keyboard, and to configure typing-break
settings.
You can set the preferences for the Keyboard Behavior
preference tool in the following functional areas:
Keyboard
Typing Break
Layouts
Layout Options
Use the Keyboard tabbed section to set general
keyboard preferences. To start the Keyboard accessibility preference tool, that is, AccessX,
click on the Accessibility button. For information
about configuring keyboard accessibility options, see Configuring Keyboard Accessibility Options.
Table 7–15 lists the keyboard preferences that you can modify.
Table 7–15 Keyboard Preferences|
Dialog Element |
Description |
Key presses repeat when key is held down |
Select this option to enable keyboard repeat. If keyboard repeat is enabled, when you press-and-hold a key, the action associated with the key is performed repeatedly. For example, if you press-and-hold a character key, the character is typed repeatedly. |
Delay |
Use the slider to specify the delay from the time you press a key to the time that the action repeats. |
Speed |
Use the slider to specify the speed at which the action is repeated. |
Cursor blinks in text boxes and fields |
Select this option to enable the cursor to blink in fields and text boxes. |
Speed |
Use the slider to specify the speed at which the cursor blinks in fields and text boxes. |
Type to test settings |
The test area is an interactive interface so you can see how the keyboard settings affect the display as you type. Type text in the test area to test the effect of your settings. |
Use the Typing Break tabbed section to set typing break preferences.
Table 7–16 lists the typing break preferences that you can modify.
Table 7–16 Typing Break Preferences|
Dialog Element |
Description |
Lock screen to enforce typing break |
Select this option to lock the screen when you are due to take a typing break. |
Work interval lasts |
Use the spin box to specify how long you can work before a typing break occurs. |
Break interval lasts |
Use the spin box to specify the length of your typing breaks. |
Allow postponing of breaks |
Select this option if you want to be able to postpone typing breaks. |
Use the Layouts tabbed section to set your keyboard layout. Select your keyboard model from the drop-down list. Use the navigational buttons to add or remove a selected layout from the list of available layouts.
You can choose different layouts to suit different locales.
Use the Layout Options tabbed section to set your keyboard layout options. Select an option from the list of available layout options, then click Add to add the option to the selected options list.
To remove an option from the Selected options list, select the option, then click Remove to remove the selected option.
To access the Keyboard Shortcuts preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Keyboard -> Shortcuts.
A keyboard shortcut is a key or combination of keys that provides an alternative to standard ways of performing an action.
Use the Shortcuts preference tool to display
the default keyboard shortcuts. You can customize the default keyboard shortcuts
to your requirements. In addition, you can also set shortcut key preferences
for multimedia functions.
You can also create hot keys on Solaris systems. Hot keys are keyboard shortcuts that start applications.
Table 7–17 lists the keyboard shortcut settings that you can customize on Linux systems.
Table 7–17 Keyboard Shortcuts Preferences on Linux Systems
Table 7–18 lists the keyboard shortcut settings that you can customize on Solaris systems.
Table 7–18 Keyboard Shortcuts Preferences on Solaris Systems
To access the Menus & Toolbars preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Menus & Toolbars.
You can use the Menus & Toolbars preference
tool to customize the appearance of menus, menubars, and toolbars for GNOME-compliant
applications.
Table 7–19 lists the menu and toolbar preferences that you can modify for GNOME-compliant applications.
Table 7–19 Menu and Toolbar Preferences
To access the Mouse preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Mouse.
Use the Mouse preference tool to configure
your mouse for right-hand use or for left-hand use. You can also specify the
speed and sensitivity of mouse movement.
You can customize the settings for the Mouse
Buttons
Cursors
Motion
Use the Buttons tabbed section to specify whether the mouse buttons are configured for left-hand use. You can also specify the delay between clicks for a double-click.
Table 7–20 lists the mouse button preferences that you can modify.
Table 7–20 Mouse Button Preferences|
Dialog Element |
Description |
Left-handed mouse |
Select this option to configure your mouse for left-hand use. When you configure your mouse for left-hand use, the functions of the left mouse button and the right mouse button are swapped. |
Timeout |
Use the slider to specify the amount of time that can pass between clicks when you double-click. If the interval between the first and second clicks exceeds the time that is specified here, the action is not interpreted as a double-click. |
Use the Cursors tabbed section to set your mouse pointer preferences.
Table 7–21 lists the mouse pointer preferences that you can modify:
Table 7–21 Mouse Pointer Preferences|
Dialog Element |
Description |
Small |
Select this option to display a small mouse pointer. |
Medium |
Select this option to display a medium mouse pointer. |
Large |
Select this option to display a large mouse pointer. |
Highlight the pointer when you press Ctrl |
Select this option to enable a mouse pointer animation when you press and release Ctrl. This feature can assist you to locate the mouse pointer. |
Use the Motion tabbed section to set your preferences for mouse movement.
Table 7–22 lists the mouse motion preferences that you can modify:
Table 7–22 Mouse Motion Preferences|
Dialog Element |
Description |
Acceleration |
Use the slider to specify the speed at which your mouse pointer moves on your screen when you move your mouse. |
Sensitivity |
Use the slider to specify how sensitive your mouse pointer is to movements of your mouse. |
Threshold |
Use the slider to specify the distance that you must move an item before the move action is interpreted as a drag-and-drop action. |
To access the Panel preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Panel.
The Panel preference tool enables you to
configure the behavior of panels. Any changes that you make with the Panel preference tool affect all of your panels.
Table 7–23 lists the panel preferences that you can modify:
Table 7–23 Panel Preferences|
Dialog Element |
Description |
Close drawer when launcher is clicked |
Select this option if you want a drawer on a panel to close when you choose a launcher in the drawer. |
Drawer and panel animation |
Select this option if you want your panels and drawers to show and to hide in an animated style. |
Animation speed |
Select the speed of the panel animation from the drop-down list. |
To access the Password preference tool, click Launch, then choose Preferences -> Password.
The Password preference tool enables you
to change your login password. To change your login password, perform the
following steps:
Start the Password preference tool. A Query dialog is displayed.
Enter the old password.
You are not prompted for the old password if you are logged on as root user.
Enter the new password, then enter the new password again to confirm.
Your new password takes effect the next time you log in.
To access the PDA Devices preference tool, click Launch, then choose Preferences -> Desktop Preferences -> PDA Devices.
A personal digital assistant (PDA) is a hand-held
computer that you can use as a personal organizer. You can store appointments,
tasks, contacts, and other information on your PDA. You can also transfer
this information between your PDA and applications in the Java Desktop System
on Linux. For example, you can copy your calendar appointments from your PDA
to Email and Calendar, and from Email
and Calendar to your PDA.
When you transfer data between your PDA and your computer, you perform a HotSync operation. The actions that occur during a HotSync operation are controlled by conduits. A conduit is an application that manages the transfer of data between your computer and your PDA.
One of the actions that you can specify for a conduit is to merge data
between your PDA and your computer. This is called a synchronize action. For example, you might add contact information to your
PDA, then add different contact information in Email and Calendar. You want to add the contact information on your PDA to Email and Calendar, and you want to add the contact information
in Email and Calendar to your PDA. To do this,
you must synchronize the data between your PDA and Email and
Calendar.
The PDA Devices preference tool enables you
to configure a PDA to work with the Java Desktop System on Linux, and to modify
PDAs that you have already configured. You can perform the following tasks
with the PDA Devices preference tool:
Configure a PDA
Modify the configuration of a PDA
Configure how PDAs can connect to your computer
Modify how PDAs can connect to your computer
Configure how conduits transfer data between your PDA and applications in the Java Desktop System
Back up PDA data
A background application waits for a PDA to attempt to synchronize with your computer. This background application is called the PDA daemon. When a PDA attempts to synchronize with the computer, the PDA daemon synchronizes the data on the PDA with data on the computer.
The PDA Monitor panel application displays
the activity of the PDA daemon. To add PDA Monitor
to a panel, right-click on the panel, then choose Add
to Panel -> Utility -> PDA Monitor. For more information about PDA Monitor, see the online Help for PDA Monitor.
You can configure a PDA in one of the following ways:
Use the Gnome Pilot Settings assistant.
If you have not configured a PDA on your computer previously, the Gnome Pilot Settings assistant is displayed when you start the PDA Devices preference tool. The Gnome Pilot Settings assistant guides you through the configuration process for
a PDA.
Use the PDA Devices preference
tool. If you have configured a PDA on your computer previously, the Pilot Settings dialog is displayed when you start the PDA Devices preference tool. Use the Pilot Settings dialog to enter details for the PDA.
Connect your PDA to your computer. If your PDA has a cradle, place the PDA in the cradle.
Click Launch, then choose Preferences -> Desktop Preferences -> PDA Devices to start the PDA Devices preference tool. Click on the Forward button in the assistant to begin the configuration process.
Enter information about how the PDA connects to your computer in the Cradle Settings page. The following table describes the settings in the Cradle Settings page:
When you complete the connection information, click on the Forward button. A Pilot Identification page is displayed.
Enter identity information for the PDA in the Pilot Identification page. The following table describes the elements in the Pilot Identification page:
Element |
Description |
Yes, I've used sync software with this pilot before |
Select this option if you have previously set the username and identifier on this PDA. If you configure a PDA with a computer, the username and ID are set on the PDA. |
No, I've never used sync software with this pilot before |
Select this option if you have not previously set the username and identifier on this PDA. |
User Name |
If you have not previously set the username and identifier on this PDA, type the username in this text box. |
ID |
If you have not previously set the username and identifier on this PDA, type the identifier in this text box. This identifier must be unique between different PDAs that you use. |
When you complete the identity information, click on the Forward button. An Initial Sync page is displayed.
Press the HotSync button on your PDA.
Depending on the option you selected on the Pilot Identification page, the Gnome Pilot Settings assistant
does one of the following:
If you selected the Yes, I've used sync software
with this pilot before option, the Gnome Pilot Settings assistant gets the username and identifier that is currently
registered on the PDA from the PDA.
If you selected the No, I've never used sync software
with this pilot before option, the Gnome Pilot Settings assistant sets the username and identifier on the PDA to the
values in the User Name text box and ID
text box.
When the initial synchronization is complete, click on the Forward button. A Pilot Attributes page is displayed.
Enter name and directory information for the PDA in the Pilot Attributes page. The following table describes the settings in the Pilot Attributes page:
Element |
Description |
Pilot Name |
Type a name for the PDA. This name identifies the PDA in the user interface. |
Local basedir |
Enter the directory where you want to store your PDA data. |
When you complete the name and directory information, click on the Forward button. A Success page is displayed.
Click on the Apply button on the Success page to close the Gnome Pilot Settings
assistant.
Alternatively, click on the Cancel button to cancel the configuration of the PDA.
In the Pilots tabbed section on the Pilot Settings dialog, click Add.
To receive the username and identifier from the PDA, click on the Get from pilot button in the Pilot Settings dialog. To assign a username and identifier to the PDA, type the username and identifier in the text boxes, then click on the Send to pilot button.
Enter name and directory information for the PDA in the Pilot Name and Local basedir fields. For more information about the fields, see To Use an Assistant.
In the Pilots tabbed section on the Pilot Settings dialog, select the PDA that you want to modify, then click Edit.
Click OK on the Pilot Settings dialog.
To configure how PDAs connect to your computer, perform the following steps:
In the Devices tabbed section on the Pilot Settings dialog, click Add.
Enter connection information for the PDA in the Device Settings dialog. For more information about the elements in the Device Settings dialog, see To Use an Assistant.
To modify how PDAs connect to your computer, perform the following steps:
In the Devices tabbed section on the Pilot Settings dialog, select the hardware settings that you want to modify, then click Edit.
Enter hardware settings for the PDA in the Device Settings dialog. For more information about the elements in the Device Settings dialog, see To Use an Assistant.
To specify how to transfer data between your PDA and applications, perform the following steps:
Ensure that the PDA daemon is active and functions properly.
To do this, add the PDA Monitor panel application
to a panel. If the PDA Monitor icon appears in
black and white, the PDA daemon is active.
In the Conduits tabbed section on the Pilot Settings dialog, use the Pilot Name drop-down list to select the PDA whose conduits you want to configure.
To enable a conduit, select the conduit from the table, then click on the Enable button. Enter configuration details for the conduit in the Conduit Settings dialog. The elements in the Conduit Settings dialog are described in the following table:
For information about the EAddress, ECalendar, and EToDo conduits, see
the online Help for Email and Calendar.
To configure a conduit that is enabled, select the conduit from the table, then click on the Settings button. Enter configuration details for the conduit in the Conduit Settings dialog.
To disable a conduit, select the conduit from the table on the Pilot Settings dialog, then click on the Disable button.
Click OK to close the Conduit Settings dialog.
You might want to back up the data on your PDA to your computer, to avoid data loss if you have a problem with your PDA. To back up PDA data to your computer, perform the following steps:
In the Conduits tabbed section on the Pilot Settings dialog, use the Pilot Name drop-down list to select the PDA whose data you want to backup.
Select the Backup conduit from the table, then click on the Enable button.
Enter configuration details for the Backup conduit in the Conduit Settings dialog. For more information about the elements in the Conduit Settings dialog, seeTo Specify How to Transfer PDA Data.
For information about how to restore backup data, see the online Help
for PDA Monitor.
To access the Printer Preferences tool, click Launch, then choose Preferences -> Printer Preferences.
You can use the Printer Preferences tool
to add printers and to manage print and job queues.
Click Launch, then choose Preferences -> Printer Preferences.
Double-click on the New Printer icon.
If you are not logged in as root user, you are prompted to enter the root password, then click OK.
Follow the instructions in the Add a Printer assistant as follows.
Specify whether you want to add a local printer attached to your computer or a remote printer attached to the network.
Before you add a remote printer, you must have the following information from your system administrator: Printer Type, Host, and Queue.
Enter the printer details.
Enter the name for your printer.
If the details you entered for your printer are correct, click Apply to add your printer.
To manage your print jobs, double-click on the printer icon. Choose the Edit menu item to perform print job management activities.
Table 7–24 lists the print job management activities that you can perform.
Table 7–24 Print Job Management Activities|
Dialog Element |
Description |
Pause Jobs |
Select this item to temporarily stop your job from printing. |
Resume Jobs |
Select this item to resume your printing job. |
Cancel Jobs |
Select this item to cancel your printing job. |
The print queue shows the documents that are waiting to be printed. You can perform printer queue management duties from the Printer menu.
To manage your printer queues, double-click on the printer icon. Choose the Printer menu item to perform printer queue management activities.
Table 7–25 lists the printer queue management activities that you can perform.
Table 7–25 Printer Queue Management Activities|
Dialog Element |
Description |
Pause Printer |
Select this item to temporarily stop your printer. |
Set as Default |
Select this item to set the current printer as your default printer. |
Print Test Page |
Select this item to print a test page. |
For documents waiting to print, you can view, but not change, the status of the job. To view your current print jobs, double-click on the printer for which you want to view the documents waiting to print.
Table 7–26 shows the information displayed for each document in the print queue.
Table 7–26 Print Job Status|
Dialog Element |
Description |
Name |
Shows the name of the document. |
Job Number |
Shows the number assigned to the print job. |
Owner |
Shows the username of the person who sent the document to the printer. |
Size |
Shows the size of the document in kilobytes. |
State |
Shows the current status of the document, such as Spooling, Paused, or Printing. |
Log in as root user.
From the Printers dialog, highlight the printer that you want to modify, then choose File -> Properties.
From the Properties dialog, you can customize the settings for printers in the following functional areas:
General
Paper
Advanced
Use the General tabbed section to view and to modify information about the selected printer, such as the printer name and location.Table 7–27 lists the general options that you can modify.
Table 7–27 General Options|
Dialog Element |
Description |
Name |
Shows the name of the selected printer. |
Description |
Provides a brief description of the selected printer. |
Location |
Shows the location of the selected printer. |
Resolution |
Use the drop-down list to select the resolution to use for the printer. |
Status |
Shows the status of the selected printer. |
Print a Test Page |
Click to print a test page. |
Use the Paper tabbed section to specify paper values, and to choose the paper layout for the selected printer.
Table 7–28 lists the paper options that you can specify.
Table 7–28 Paper Options|
Dialog Element |
Description |
Paper size |
Use the drop-down list to select the paper size to use for the printer. |
Paper type |
Use the drop-down list to select the paper type to use for the printer. |
Source |
Use the drop-down list to select the paper tray to use for the printer. The source specifies where the paper is located in the printer. |
Double Sided |
Use the drop-down list to select the layout to use for the printer. |
Use the Advanced tabbed section to specify advanced values for the selected printer.
Table 7–29 lists an example of advanced options that you can specify for a specific printer.
Table 7–29 Advanced Options|
Dialog Element |
Description |
Floyd-Steinberg Dithering |
Use the drop-down list to select the type of dithering to use for the printer, for example, Floyd-Steinberg dithering. |
Manual Feed of Paper |
Use the drop-down list to select whether you want to switch on or off the paper manual feed. |
Page Region |
Number of Copies |
Use the drop-down list to select the number of copies that you want to print. |
Density |
Use the drop-down list to select the density to use for the printer. |
Economy mode |
Use the drop-down list to select the economy mode to use for the printer. |
RET Setting |
Use the drop-down list to select the Resolution Enhancement Technology (RET) setting to use for the printer. RET inserts smaller dots at the edges of lines and smooths any rough edges. |
To access the Preferred Applications preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Preferred Applications.
Use the Preferred Applications preference
tool to specify the applications that you want the Java Desktop System to
use when the preferred application starts. For example, you can specify Xterm as your preferred terminal application. When you click Launch, then choose Applications -> Utilities -> Terminal, Xterm starts.
You can customize the preferences for the Preferred Applications preference tool in the following functional areas:
Web Browser
Mail Reader
Text Editor
Terminal
Use the Web Browser
tabbed section to configure your preferred web browser. The preferred web
browser opens when you click on a URL. For example, the preferred web browser
opens when you select a URL in an application, or when you select a URL launcher
Table 7–30 lists the preferred web browser preferences that you can modify.
Table 7–30 Preferred Web Browser Preferences|
Dialog Element |
Description |
Select a Web Browser |
Select this option if you want to use a standard web browser. Use the drop-down combination box to select your preferred web browser. |
Custom Web Browser |
Select this option if you want to use a custom web browser. |
Command |
Enter the command to start the custom web browser. To enable the browser to display a URL that you click on, include “%s” after the command. |
Start in Terminal |
Select this option to run the command in a terminal window. Select this option for a browser that does not create a window in which to run. |
Use the Mail Reader
tabbed section to configure your preferred email client.
Table 7–31 lists the preferred email client preferences that you can modify.
Table 7–31 Preferred Email Client Preferences|
Dialog Element |
Description |
Select a Mail Reader |
Select this option if you want to use a standard email client. Use the drop-down combination box to select your preferred email client. |
Custom Mail Reader |
Select this option if you want to use a custom email client. |
Command |
Enter the command to start the custom email client. |
Start in Terminal |
Select this option to run the command in a terminal window. Select this option for an email client that does not create a window in which to run. |
Use the Text Editor
tabbed section to configure your preferred text editor.
Table 7–32 lists the preferred text editor preferences that you can modify.
Table 7–32 Preferred Text Editor Preferences
Use the Terminal tabbed section
to configure your preferred terminal.
Table 7–33 lists the preferred terminal preferences that you can modify.
Table 7–33 Preferred Terminal Preferences|
Dialog Element |
Description |
Select a Terminal |
Select this option if you want to use a standard terminal. Use the drop-down combination box to specify your preferred terminal application. |
Custom Terminal |
Select this option if you want to use a custom terminal application. |
Command |
Enter the command to start the custom terminal. |
Exec Flag |
Enter the exec option to use with the command application. |
To access the Remote Desktop
preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Remote Desktop.The Remote Desktop preference tool enables you to share a Desktop
session between multiple users, and to set remote desktop preferences.
Table 7–34 lists the remote desktop preferences that you can set. These preferences have a direct impact on the security of your system.
Table 7–34 Remote Desktop Preferences
To access the Screen Resolution preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Screen Resolution.
Use the Screen Resolution preference tool
to specify the resolution settings for your screen. Table 7–35
lists the screen resolution preferences that you can modify.
Dialog Element |
Description |
Resolution |
Use the drop-down list to select the resolution to use for the screen. |
Refresh rate |
Use the drop-down list to select the screen refresh rate to use for the screen. |
Make default for this computer (name) only |
Select this option to make the screen resolution settings the default settings for the system that you are logged in to only. |
To access the Screensaver preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Screensaver.
A screensaver is an application that you can use to replace the image on your screen when the screen is not in use. You can use screensavers in the following ways:
Activate after a specified period of idle time.
Activate when you lock your screen.
Manage power used by your monitor when your system is idle.
You can customize the settings for the Screensaver
Display Modes
Advanced
Use the Display Modes tabbed section to set display mode preferences.
Table 7–36 lists the display mode preferences that you can modify.
Table 7–36 Screensaver Display Mode Preferences
Use the Advanced tabbed section to set advanced screensaver preferences.
Table 7–37 lists the advanced screensaver preferences that you can modify.
Table 7–37 Advanced Screensaver Preferences|
Dialog Element |
Description |
Grab Desktop Images |
Some screensavers can take a screenshot of your screen, then manipulate the screenshot to create your screensaver display. Select this option to enable screensavers to take a screenshot of your screen. |
Grab Video Frames |
Some screensavers can capture a frame of video, then manipulate the captured image to create your screensaver display. If your system has a video capture card, select this option to enable screensavers to capture a frame of video. |
Choose Random Image |
Select this option to enable screensavers to use images from a directory that you select. Type the path for the directory in the field. Alternatively, click Browse to display a dialog from which you can select a directory. |
Verbose Diagnostics |
Select this option if you want to display screensaver diagnostic information. |
Display Subprocess Errors |
Select this option if you want to display errors related to screensaver subprocesses. |
Display Splash Screen at Startup |
Select this option if you want |
Power Management Enabled |
Select this option to enable power management of your monitor. Power management can reduce energy consumption by your monitor when you are not using the monitor. |
Standby After |
Use the spin box to specify how long to wait to put the monitor in standby mode. When the monitor is in standby mode, the screen is black. |
Suspend After |
Use the spin box to specify how long to wait to put the monitor in power-saving mode. |
Off After |
Use the spin box to specify how long to wait to switch off the monitor. |
Install Colormap |
Select this option to install a private colormap when the screensaver is active. Use of a private colormap might improve the quality of the colors in particular screensaver displays. |
Fade to Black When Blanking |
Select this option if you want your display to fade to black when the screensaver activates. |
Fade from Black When Unblanking |
Select this option if you want your display to fade from black to the screen contents when the screensaver stops. |
Fade Duration |
Use the spin box to specify how long to take to fade to black when the screensaver activates. |
To access the Sessions preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Sessions.
The Sessions preference tool enables you
to manage your sessions. You can set session preferences, and specify which
applications to start when you start a session. You can configure sessions
to save the state of applications in the Java Desktop System, and to restore
the state when you start another session. You can also use this preference
tool to manage multiple Java Desktop System sessions.
You can customize the settings for sessions and startup applications in the following functional areas:
Session Options
Current Session
Startup Programs
Use the Session Options tabbed section to manage multiple sessions, and to set preferences for the current session.
Table 7–38 lists the session options that you can modify.
Table 7–38 Session Options
Use the Current Session tabbed section to specify startup order values, and to choose restart styles for the session-managed applications in your current session.
Table 7–39 lists the session properties that you can configure.
Table 7–39 Session Properties
Use the Startup Programs
tabbed section of the Sessions preference tool
to specify non-session-managed startup applications.
Startup applications are applications that start automatically when you start
a session. You specify the commands that run the non-session-managed applications
in the Startup Programs tabbed section. The commands
execute automatically when you log in.
You can also start session-managed applications automatically. For more information, see Setting Session Properties.
Table 7–40 lists the startup applications preferences that you can modify.
Table 7–40 Startup Programs Preferences
To access the Sound preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Sound.
The Sound preference tool enables you to
control when the Java Desktop System sound server starts. You can also specify
which sounds to play when particular events occur.
You can customize the settings for the Sound
General
Sound Events
System Bell
Use the General tabbed section of the Sound preference tool to specify when to launch the Java Desktop
System sound server. You can also enable sound event functions.
Table 7–41 lists the general sound preferences that you can modify.
Table 7–41 General Sound Preferences|
Dialog Element |
Description |
Enable sound server startup |
Select this option to start the sound server when you start a session. When the sound server is active, the Java Desktop System can play sounds. |
Sounds for events |
Select this option to play sounds when particular events occur in the Java Desktop System. You can select this option only if the Enable sound server startup option is selected. |
Use the Sound Events tabbed section of the Sound preference tool to associate particular sounds with particular
events.
You must select the Enable sound server startup option, and the Sounds for events option before you can access the components on the Sound Events tabbed section.
Table 7–42 lists the sound event preferences that you can modify.
Table 7–42 Sound Event Preferences|
Dialog Element |
Description |
Sounds table |
Use the Sounds table to associate particular sounds with particular events. The Event column displays a hierarchical list of events that can occur. To expand a category of events, click on the right arrow beside a category of events. The Sound File column lists the sound file that plays when the event occurs. |
Play |
Click on this button to play the sound file that is associated with the selected event. |
Sound file |
To associate a sound with an event, select the event in the Sounds table. Use the Sound file drop-down combination box to enter the name of the sound file that you want to associate with the selected event. Alternatively, click Browse to display a Select Sound File dialog. Use the dialog to specify the sound file that you want to associate with the selected event. Note – You can only associate .wav format sound files with events. |
Use the System Bell tabbed section to set your preferences for the system bell.
Some applications play a bell sound to indicate a keyboard input error. Use the preferences in the System Bell tabbed section to configure the bell sound. Table 7–43 lists the system bell preferences that you can modify.
Table 7–43 System Bell Preferences|
Dialog Element |
Description |
Sound an audible bell |
Select this option to enable the system bell. |
Visual feedback |
Select this option to enable visual feedback to indicate input errors. |
Flash window titlebar |
Select this option if you want window titlebars to flash to indicate an input error. |
Flash entire screen |
Select this option if you want the entire screen to flash to indicate an input error. |
To access the Theme preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Theme.
A theme is a group of coordinated settings that specifies the visual
appearance of a part of the Java Desktop System. You can choose themes to
change the appearance of the Java Desktop System. Use the Theme preference tool to select a theme. You can choose from a list
of available themes. The list of available themes includes several themes
for users with accessibility requirements.
A theme contains settings that affect different parts of the Java Desktop System, as follows:
The
controls setting for a theme determines the visual appearance of windows,
panels, and panel applications. The controls setting also determines the visual
appearance of the GNOME-compliant interface items that appear on windows,
panels, and panel applications, such as menus, icons, and buttons. Some of
the controls setting options that are available are designed for special accessibility
needs. You can choose an option for the controls setting from the Controls tabbed section in the Theme
preference tool.
The
window frame setting for a theme determines the appearance of the frames around
windows only. You can choose an option for the window frame setting from the Window Border tabbed section in the Theme
preference tool.
The icon
setting for a theme determines the appearance of icons on panels and on the
desktop background. You can choose an option for the icon setting from the Icons tabbed section in the Theme preference
tool.
The themes that are listed in the Theme preference
tool are different combinations of control options, window frame options,
and icon options. You can create a custom theme that uses different combinations
of control options, window frame options, and icon options.
To create a custom theme, perform the following steps:
Start the Theme preference tool.
Select a theme in the list of themes.
Click on the Theme Details button. A Theme Details dialog is displayed.
Click on the Controls tab to display the Controls tabbed section. Select the controls option that you want to use in the custom theme from the list of available options. The list of available control options includes several options for users with accessibility requirements.
Click on the Window Border tab to display the Window Border tabbed section. Select the window frame option that you want to use in the custom theme from the list of available options. The list of available window frame options includes several options for users with accessibility requirements.
Click on the Icons tab to display the Icons tabbed section. Select the icons option that you want to use in the custom theme from the list of available options. The list of available icon options includes several options for users with accessibility requirements.
Click Close to close the Theme Details dialog.
On the Theme preferences tool,
click on the Save Theme button.
Type a name and a short description for the custom theme in the Save Theme to Disk dialog, then click Save. The custom theme appears in your list of available themes.
You can add a theme to the list of available themes. The new theme must be an archive file that is tarred and zipped. That is, the new theme must be a .tar.gz file.
To install a new theme, perform the following steps:
Click on the Install Theme button.
Enter the location of the theme archive file in the drop-down combination box of the Theme Installation dialog. Alternatively, to browse for the file, click on the Browse button. When you have selected the file, click Open.
Click on the Install button to install the new theme.
You can install new controls options, window frame options, or icons options. You can find many controls options on the Internet.
To install a new controls option, window frame option, or icons option, perform the following steps:
Click on a tab in the Theme Details dialog for the type of theme that you want to install. For example, to install an icons option, click on the Icons tab.
Enter the location of the option archive file in the drop-down combination box of the Theme Installation dialog. Alternatively, to browse for the file, click on the Browse button. When you have selected the file, click Open.
Click on the Install button to install the new option.
You can delete controls options, window frame options, or icons options.
To delete a controls option, window frame option, or icons option, perform the following steps:
Click on a tab in the Theme Details dialog for the type of option that you want to delete.
Click on the Go to Theme Folder button. A file manager window opens on the default option folder.
Use the file manager window to delete the option.
To access the Window Behavior preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display ->Window Behavior.
Use the Window Behavior preference tool to
customize window behavior for the Java Desktop System.
Table 7–44 lists the window preferences that you can modify.
Table 7–44 Window Preferences
To access the Wireless Network Configuration preference tool, click Launch, then choose Preferences -> Wireless Network Configuration.
Follow the instructions in the Wireless Network Configuration assistant to edit and switch to a different wireless network.
