The themes that are listed in the Theme preference
tool are different combinations of control options, window frame options,
and icon options. You can create a custom theme that uses different combinations
of control options, window frame options, and icon options.
To create a custom theme, perform the following steps:
Start the Theme preference tool.
Select a theme in the list of themes.
Click on the Theme Details button. A Theme Details dialog is displayed.
Click on the Controls tab to display the Controls tabbed section. Select the controls option that you want to use in the custom theme from the list of available options. The list of available control options includes several options for users with accessibility requirements.
Click on the Window Border tab to display the Window Border tabbed section. Select the window frame option that you want to use in the custom theme from the list of available options. The list of available window frame options includes several options for users with accessibility requirements.
Click on the Icons tab to display the Icons tabbed section. Select the icons option that you want to use in the custom theme from the list of available options. The list of available icon options includes several options for users with accessibility requirements.
Click Close to close the Theme Details dialog.
On the Theme preferences tool,
click on the Save Theme button.
Type a name and a short description for the custom theme in the Save Theme to Disk dialog, then click Save. The custom theme appears in your list of available themes.
