Use the Typing Break tabbed section to set typing break preferences.
Table 7–16 lists the typing break preferences that you can modify.
Table 7–16 Typing Break Preferences|
Dialog Element |
Description |
Lock screen to enforce typing break |
Select this option to lock the screen when you are due to take a typing break. |
Work interval lasts |
Use the spin box to specify how long you can work before a typing break occurs. |
Break interval lasts |
Use the spin box to specify the length of your typing breaks. |
Allow postponing of breaks |
Select this option if you want to be able to postpone typing breaks. |
