Java Desktop System Release 3 User Guide
To Add a Service
Perform the following steps:
  1. Start the File Associations preference tool.
  2. Click on the Add Service button.
  3. Enter the properties of the service in the Add Service dialog.
    The following table describes the dialog elements on the Add Service dialog:
    Dialog Element
    Description
    Description
    Enter a description of the service.
    Protocol
    Enter the protocol for the service.
    Program to Run
    Use the drop-down list to select a program to run for this service.
    Program
    Specify the program to associate with the service. Enter the command to start the program. Alternatively, to choose a command that you entered previously, click the down arrow button, then choose the command.
    You can also use the Browse button to choose a command.
    Run in Terminal
    Select this option to run the program in a terminal window. Choose this option for a program that does not create a window in which to run.
  4. Click OK.
