Java Desktop System Release 3 User Guide
Customizing Windows
To access the Window Behavior preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display ->Window Behavior.
Use the Window Behavior preference tool to customize window behavior for the Java Desktop System.
Table 7–44 lists the window preferences that you can modify.
Table 7–44 Window Preferences
Dialog Element
Description
Select windows when the mouse moves over them
Select this option to give focus to a window when you point to the window. The window retains focus until you point to another window.
Raise selected windows after an interval
Select this option to raise windows a short time after the window receives focus.
Interval before raising
Use the slider to specify the interval to wait before raising a window that has received focus.
Double-click titlebar to perform this action
Use the drop-down list to select the behavior that you want to occur when you double-click on a window titlebar. Select one of the following options:
  • Roll up: Shades the window.
  • Maximize: Maximizes the window.
To move a window, press-and-hold this key then grab the window
Select the key to press-and-hold when you drag a window to move the window.
