Java Desktop System Release 3 User Guide
To Move a File or Folder
You can move a file or folder from the file manager to the desktop background. To move a file or folder to the desktop background, perform the following steps:
  1. Open a file manager window.
  2. Display the file or folder that you want to move.
  3. Drag the file or folder to the desktop background. The icon for the file or folder is moved to the desktop background. The file or folder is moved to your Desktop directory.
    Alternatively, select the file or folder, then choose Edit -> Cut Files. Right-click on any desktop background object, then choose Paste Files.
