Java Desktop System Release 3 User Guide
To Remove an Object
To remove an object from the desktop background, right-click on the object, then choose Move to Trash. Alternatively, drag the object to Trash.
Note –
When you move a file or folder from a removable media to Trash, the file or folder is stored in a Trash location on the removable media. To remove the file or folder permanently from the removable media, you must empty Trash.
