Java Desktop System Release 3 User Guide
To Change Permissions
To change the permissions of a desktop background object, perform the following steps:
  1. Right-click on the object whose permissions you want to change, then choose Properties.
  2. Click on the Permissions tab in the properties dialog.
  3. In the Permissions tabbed section, use the drop-down lists and check boxes to change the permissions for the file or folder. For more information on the dialog elements in the Permissions tabbed section, see Using Your File Manager.
  4. Click Close to close the properties dialog.
