Java Desktop System Release 3 User Guide
To Resize an Icon
You can change the size of the icon that represents a desktop background object. To change the size of an icon on the desktop background, perform the following steps:
  1. Right-click on the desktop background object whose icon you want to resize, then choose Stretch Icon. A rectangle appears around the icon, with a handle at each corner.
  2. Grab one of the handles, then drag the icon to the size that you want.
    To return the icon to the original size, right-click on the icon, then choose Restore Icon's Original Size.
