Java Desktop System Release 3 User Guide
Menu Bar
Menu Bar panel application. Menus: Applications, Actions.
The Menu Bar provides access to the Applications and Actions menus. You can access almost all of the standard applications, commands, and configuration options from the Menu Bar.
To Add a Menu Bar to a Panel
You can add as many Menu Bar panel applications as you want to your panels. To add a Menu Bar to a panel, right-click on any vacant space on the panel. Choose Add to Panel -> Menu Bar.
