Java Desktop System Release 3 User Guide
Managing Your Desktop Session
To configure your desktop session, use the Sessions preference tool as described in Configuring Sessions. The Sessions preference tool recognizes the following types of application:
To Define Log In and Log Out Behavior
To set how a session behaves when you log in and log out, use the Sessions preference tool. Make the changes you require in the Session Options tabbed section. For example, you can display a splash screen when you log in.
To Use Startup Applications
You can configure your sessions to start applications that are not session-managed. To configure non-session-managed startup applications, use the Sessions preference tool. Use the Startup Programs tabbed section to add, edit, and delete applications. If you save your settings and log out, the startup applications start automatically the next time that you log in.
To Browse Applications
To browse the applications in the current session, use the Sessions preference tool. The Current Session tabbed section lists the following:
You can use the Current Session tabbed section to perform a limited number of actions on the session properties of an application or preference tool. For example, you can edit the startup order or restart style of any Java Desktop System application or preference tool that is in the list.
To Save Your Session Settings
Perform the following steps:
  1. Open the Sessions preference tool.
  2. Select the Automatically save changes to session option on the Session Options tabbed section.
  3. Close the Sessions preference tool.
  4. End your session as described in Logging Out.
  5. When you log out, a dialog displays a Save current setup checkbox. If you want to save your current settings, select the Save current setup checkbox, then continue to log out.
