Java Desktop System Release 3 User Guide
To Copy a File or Folder
The following sections describe the ways you can copy a file or folder.
Drag to the New Location in a View Pane
To copy a file or folder perform the following steps:
  1. Open a file manager window. Choose File -> New Window to open a second file manager window.
  2. In one window, select the folder from which you want to copy the file or folder. In the other window, select the folder to which you want to copy the file or folder.
  3. Grab the file or folder, then press-and-hold Ctrl. Drag the file or folder to the new location in the other window.
To copy the file or folder to a folder that is one level below the current location, do not open a new window. Instead, grab the file or folder, then press-and-hold Ctrl. Drag the file or folder to the new location in the same window.
Copy and Paste to the New Location
You can copy a file or folder and paste the file or folder into another folder, as follows:
  1. Select the file or folder that you want to copy, then choose Edit -> Copy File.
  2. Open the folder to which you want to copy the file or folder, then choose Edit -> Paste Files.
