You can change the size of items in a view. You can change the size if the view displays a file or a folder. You can change the size of items in a view in the following ways:
To enlarge the size of items in a view, choose View -> Zoom In.
To reduce the size of items in a view, choose View -> Zoom Out.
To return items in a view to the normal size, choose View -> Normal Size.
You can also use the zoom buttons on the location bar to change the size of items in a view. Table 5–6 describes how to use the zoom buttons.
Table 5–6 Zoom Buttons|
Button |
Button Name |
Description |
Zoom Out button |
Click on this button to reduce the size of items in a view. |
Normal Size button |
Click on this button to return items in a view to normal size. |
Zoom In button |
Click on this button to enlarge the size of items in a view. |
The file manager remembers the size of items in a particular folder. The next time that you display the folder, the items are displayed in the size that you selected. In other words, when you change the size of items in a folder, you customize the folder to display the items at that size. To return the size of the items to the default size specified in your preferences, choose View -> Reset View to Defaults.
