Java Desktop System Release 3 User Guide
To Resize an Icon in Icon View
In icon view, you can change the size of the icon that represents an item that is displayed. To change the size of an item in icon view, perform the following steps:
  1. Right-click on the item that you want to resize, then choose Stretch Icon. A rectangle appears around the item, with a handle at each corner.
  2. Grab one of the handles, then drag the icon to the size that you want.
    To return the icon to the original size, right-click on the icon, then choose Restore Icon's Original Size.
You can also resize objects on the desktop background.
