Java Desktop System Release 3 User Guide
To Create a Folder
To create a folder perform the following steps:
  1. Select the folder where you want to create the new folder.
  2. Choose File -> Create Folder. Alternatively, right-click on the background of the view pane, then choose Create Folder.
    An untitled folder is added to the view pane. The name of the folder is selected.
  3. Type a name for the folder, then press Return.
