The file manager provides an integrated access point to your files, applications, FTP sites, and URIs.
This section describes the following:
How to display items in file manager windows.
How to open files from file manager windows.
How to navigate the files and folders in your file system.
How to open locations on your file system.
How to navigate to FTP sites.
How to access special URI locations.
You can display the contents of a folder in any of the following ways:
Double-click on the folder in the view pane.
In the Location field, type the path of the folder that you want to display, then press Return. The Location field includes an autocomplete feature. As you type a path, the file manager reads your file system. When you type enough characters to uniquely identify a directory, the file manager completes the name of the directory in the Location field.
Use the Tree in the side pane. For more information, see Using the Tree From the Side Pane.
Use the Back toolbar button and the Forward toolbar button to browse through your navigation history.
To change to the folder that is one level above the current folder, choose Go -> Up. Alternatively, click on the Up toolbar button.
To reload the display, click on the Reload button.
If you cannot find the folder that you want to display, you can use Search Tool. To start the Search Tool,
click Launch, then choose Find Files.
The Tree displays a hierarchical representation of your file system. The Tree provides a convenient way to navigate your file system. To display the Tree in the side pane, choose Tree from the drop-down list at the top of the side pane.
In the Tree, folders are represented as follows:
Folder State |
Graphic Representation |
Closed folder |
Right arrow |
Open folder |
Down arrow |
Table 5–2 describes the tasks that you can perform with the Tree, and how to perform the tasks.
Table 5–2 Tree Tasks|
Task |
Action |
Open the Tree. |
Choose Tree from the drop-down list at the top of the side pane. |
Close the Tree. |
Choose another item from the drop-down list at the top of the side pane. |
Open a folder in the Tree. |
Click on the arrow next to the folder in the Tree. |
Close a folder in the Tree. |
Display the contents of a folder in the view pane. |
Select the folder in the Tree. |
Display the contents of a file in the view pane. |
Select the file in the Tree. |
You can set your preferences so that the Tree does not display files.
When you open a file, the file manager performs the default action for that file type. The default action can be one of the following:
Use a viewer component to display the file in the view pane.
Launch an application that opens the file.
The file manager checks the contents of a file to determine the type of a file. If the first lines do not determine the type of the file, then the file manager checks the file extension.
If you cannot find the file that you want to open, you can use Search Tool. To start the Search Tool,
The file manager contains viewer components that enable you to display particular types of file in the view pane. For example, you can display the following types of files in the view pane:
Plain text files
PNG files
Joint Photographic Experts Group (JPEG) files
To reload the contents of the view pane, choose View -> Reload. To stop loading an item in the view pane, choose View -> Stop.
When you display a file in the view pane, the viewer component might add menu items to the file manager menus. The menu items relate to the file type that is displayed. For example, when you display a PNG file, the Edit menu contains flip and rotate menu items.
Also, when you display some types of file in the view pane, you can use the file manager zoom buttons to change the size of the item.
To execute the default action for a file, double-click on the file. For example, if the default action for plain text documents is to display the file in a text viewer. In this case, you can double-click on the file to display the file in a text viewer.
You can set your file manager preferences so that you click once on a file to execute the default action.
To execute actions other than the default action for a file, perform the following steps:
In the view pane, select the file that you want to perform
an action on. Choose File -> Open With. The Open With
submenu opens. The items in this submenu correspond to the contents of the
following parts of the File Associations preference
tool:
Default action drop-down list in the Edit file type dialog
Viewer component drop-down list in the Edit file type dialog
Choose an action from the Open With submenu.
When you display a file in the view pane, the side pane might contain buttons.
The buttons represent any actions that are defined in the File Associations preference tool. The actions are defined in
the Default action drop-down list in the Edit
file type dialog in the File Associations
preference tool. Click on a button to execute an action. For example, if an
action defined for plain text documents is to open the file in the gedit text editor. If this action is defined, an Open with gedit button is displayed in the side pane. To open
the file in the gedit application, click on the Open with gedit button.
A button that represents the action does not appear in the side pane if the actions are excluded in either of the following dialogs:
Open with Other Application
Open with Other Viewer
You can use the file manager to quickly access different locations on your file system. To open a location, perform the following steps:
Choose Go -> Location.
Press Return.
The Location field includes an autocomplete feature. As you type a path, the file manager reads your file system. When you type enough characters to uniquely identify a directory, the file manager autocompletes the name of the directory in the Location field.
The This Computer location enables you to access the following functions:
Applications
Double-click Applications to access your key Java
Desktop Systems applications. You can also access the Applications menu through the Launch menu and the Menu Bar.
Documents
Double-click on Documents to access your home folder. Alternatively, double-click on the Documents object on the desktop background.
File System
Double-click on File System to access the top level folder of the Java Desktop System. You can also access your CD-ROM, and floppy drives from here.
Network Places
Double-click on Network Places to displays network locations to which you can connect, if your system is configured to access locations on a network.
Preferences
Double-click on Preferences to customize the Java Desktop System. You can also access the preference tools through the Launch menu
You can access the This Computer location in the following ways:
From the desktop background
Double-click on the This Computer object on the desktop background. The contents of the This Computer location are displayed in a file browser window.
From a file browser window, access the computer:/// URI.
You can use the file manager to access FTP sites. To access an FTP site, enter the URL for the site in the field on the location bar, then press Return. The contents of the site are displayed in the view pane. To copy a file from the FTP site, drag the file to the new location.
To access an FTP site that requires a username and password, you can enter the URL in the following form:
ftp://username:password@hostname.domain
To reload the FTP site in the view pane, choose View -> Reload. To stop loading the FTP site, choose View -> Stop.
If your system is configured to access places on a network, you can use the file manager to access the network places.
To access network places, open the file manager and choose File -> Add Network Place. Alternatively, double-click on the Network Places object on the desktop background. A file manager window is displayed. The window displays the network places that you can access. Double-click on the network that you want to access.
To access Windows shares, double-click on the Windows Network (SMB) object. A list of the Windows shares available to you is displayed in the file manager window.
To add a network place, perform the following steps:
If your system is configured to access places on a network, open the file manager and choose File -> Add Network Place. Alternatively, double-click on the Network Places object on the desktop background.
Double-click on the Add Network Place object. The Add Network Place dialog is displayed. Enter the details of the server in the dialog, as follows:
Click on the Connect button to connect to your network place. Otherwise, click Cancel to close the Add Network Place dialog.
The Java Desktop System contains special URI locations that enable you to access particular functions from the file manager. For example, to access the preference tools, you can access the preferences:/// URI in a file manager window. Table 5–3 lists the special URI locations that you can use with the file manager.
Table 5–3 Special URI Locations|
URI Location |
Description |
applications:/// |
Displays a list of the applications in the Java Desktop System. The applications are the same as the applications in the Applications menu. To open an application, double-click on the application. |
computer:/// |
Displays a list of applications and preference tools in the Java Desktop System. Also displays icons to access your file system, CD-ROM, and floppy drives. |
network:/// |
Displays network locations to which you can connect, if your system is configured to access locations on a network. To access a network location, double-click on the network location. You can also use this URI to add network locations to your system. |
preferences:/// |
Displays a list of the preference tools in the Java Desktop System. The preference tools are the same as the preference tools in the Preferences menu. To open a preference tool, double-click on the preference tool. |
server-settings:/// |
Displays a list of applications that you can use to configure your system as a server. |
system-settings:/// |
Displays a list of applications that you can use to modify your system settings. |
The file manager maintains a history list of files, folders, FTP sites, and URI locations. You can use the history list to navigate to files, folders, FTP sites, and URI locations that you have recently visited. Your history list contains the last ten items that you viewed. The following sections describe how to navigate your history list.
To clear your history list choose Go -> Clear History.
To display a list of previously-viewed items, choose the Go menu. Your history list is displayed in the lower part of the Go menu. To open an item in your history list, choose the item from the Go menu.
To use the toolbar to navigate your history list, perform one of the following actions:
To open the previous file, folder, or URI in your history list, click on the Back toolbar button.
To open the next file, folder, or URI in your history list, click on the Forward toolbar button.
To display a list of previously-viewed items, click on the down arrow to the right of the Back toolbar button. To open an item from this list, click on the item.
To display a list of items that you viewed after you viewed the current item, click on the down arrow to the right of the Forward toolbar button. To open an item from this list, click on the item.
To display the History list in the side pane, choose History from the drop-down list at the top of the side pane. The History list in the side pane displays a list of your previously-viewed items.
To display an item from your history list in the view pane, click on the item in the History list.
To access an item in your bookmarks, choose the item from the Bookmarks menu. You can add your favorite locations to your Bookmarks menu. You can add bookmarks to files and folders in your file system, to FTP sites, or to URI locations.
To add a bookmark, display the item that you want to bookmark in the view pane. Choose Bookmarks -> Add Bookmark.
To edit your bookmarks perform the following steps:
Choose Bookmarks -> Edit Bookmarks.
To edit a bookmark, select the bookmark on the left side of the Edit Bookmarks dialog. Edit the details for the bookmark on the right side of the Edit Bookmarks dialog, as follows:
Dialog Element |
Description |
Name |
Use this text box to specify the name that identifies the bookmark in the Bookmarks menu. |
Location |
Use this field to specify the location of the bookmark. |
To delete a bookmark, select the bookmark on the left side of the dialog. Click Delete.
