Java Desktop System Release 3 User Guide
To Execute the Default Action
To execute the default action for a file, double-click on the file. For example, if the default action for plain text documents is to display the file in a text viewer. In this case, you can double-click on the file to display the file in a text viewer.
You can set your file manager preferences so that you click once on a file to execute the default action.
