Java Desktop System Release 3 User Guide
To Bookmark Your Favorite Locations
To access an item in your bookmarks, choose the item from the Bookmarks menu. You can add your favorite locations to your Bookmarks menu. You can add bookmarks to files and folders in your file system, to FTP sites, or to URI locations.
To Add a Bookmark
To add a bookmark, display the item that you want to bookmark in the view pane. Choose Bookmarks -> Add Bookmark.
To Edit a Bookmark
To edit your bookmarks perform the following steps:
  1. Choose Bookmarks -> Edit Bookmarks.
  2. To edit a bookmark, select the bookmark on the left side of the Edit Bookmarks dialog. Edit the details for the bookmark on the right side of the Edit Bookmarks dialog, as follows:
    Dialog Element
    Description
    Name
    Use this text box to specify the name that identifies the bookmark in the Bookmarks menu.
    Location
    Use this field to specify the location of the bookmark.
  3. To delete a bookmark, select the bookmark on the left side of the dialog. Click Delete.
