The This Computer location enables you to access the following functions:
Applications
Double-click Applications to access your key Java
Desktop Systems applications. You can also access the Applications menu through the Launch menu and the Menu Bar
Documents
Double-click on Documents to access your home folder. Alternatively, double-click on the Documents object on the desktop background.
File System
Double-click on File System to access the top level folder of the Java Desktop System. You can also access your CD-ROM, and floppy drives from here.
Network Places
Double-click on Network Places to displays network locations to which you can connect, if your system is configured to access locations on a network.
Preferences
Double-click on Preferences to customize the Java Desktop System. You can also access the preference tools through the Launch menu
You can access the This Computer location in the following ways:
From the desktop background
Double-click on the This Computer object on the desktop background. The contents of the This Computer location are displayed in a file browser window.
From a file browser window, access the computer:/// URI.
