To Format Media on Solaris Systems
To format media is to prepare the
media for use with a particular file system.
When you format media, you overwrite any existing information on the
media. To format media, perform the following steps:
Right-click on the object that represents the media on the
desktop, then choose Format. A Media
Format dialog is displayed.
Select your format options in the Media Format
dialog. The following table describes the elements on the dialog:
Dialog Element
Description
Quick Format
Select this option to format without certification,
or with limited certification of certain tracks on the media.
Long Format
Select this option to perform a complete format.
For some devices this might include certification of whole media by the drive.
File System Type
Use the drop-down list to select the type of file
system in which you want to format the media. Select from the following options:
PCFS (DOS): Select this option if you
want to use the media on an MS-DOS operating system.
UFS (UNIX): Select this option if you
want to use the media on a UNIX operating system.
UDFS (UNIX): Select this option if you
want to format the media in Universal Disk File System (UDFS).
NEC (DOS): Select this option if you
want to format the media in the NEC file system.
Volume Label
Type the name for the media in
the text box.
Click Apply to format the media.
