Java Desktop System Release 3 User Guide
To Access Network Places
If your system is configured to access places on a network, you can use the file manager to access the network places.
To access network places, open the file manager and choose File -> Add Network Place. Alternatively, double-click on the Network Places object on the desktop background. A file manager window is displayed. The window displays the network places that you can access. Double-click on the network that you want to access.
To access Windows shares, double-click on the Windows Network (SMB) object. A list of the Windows shares available to you is displayed in the file manager window.
To Add a Network Place
To add a network place, perform the following steps:
  1. If your system is configured to access places on a network, open the file manager and choose File -> Add Network Place. Alternatively, double-click on the Network Places object on the desktop background.
  2. Double-click on the Add Network Place object. The Add Network Place dialog is displayed. Enter the details of the server in the dialog, as follows:
    Dialog Element
    Description
    Location
    Use this text box to specify the location that you want to add. Alternatively, select one of the following locations from the drop-down list:
    • FTP Server
    • Web Folder
    • Windows Network (SMB)
    Shortcut name
     Use this text box to specify a shortcut name for the network place.
    Anonymous login
    FTP Server option only. Select this option to log in to the FTP server as an anonymous user.
    No login required
    Web Folder and Windows Network (SMB) options only. Select this option if you do not need to log in to the web folder, or Windows share.
    Username
    Use this text box to specify a username when you connect to the specified network place.
    When you connect to the network place, you must enter your password.
    Go there now
    Select this option if you want to access the network place immediately.
  3. Click on the Connect button to connect to your network place. Otherwise, click Cancel to close the Add Network Place dialog.
