Java Desktop System Release 3 User Guide
Templates and Documents
You can create templates from documents that you frequently create. For example, if you often create invoices, you can create an empty invoice document and save the document as invoice.doc in the $HOME/Templates folder.
You can also access the templates folder from a file browser window. Choose Go -> Templates.
The template name is displayed as a submenu item in the Create Document menu.
You can also create subfolders in the template folder. Subfolders display as submenus in the menu.
You can also share templates. Create a symbolic link from the template folder to the folder that contains the shared templates.
