To add a pattern to the patterns that you can use on your screen components, choose Edit -> Backgrounds and Emblems in a file manager window. Click on the Patterns button, then click on the Add a New Pattern button. A dialog is displayed. Use the dialog to select the new pattern. Click OK to add the new pattern to the Backgrounds and Emblems dialog.
