Perform the following steps:
On the login screen, choose Options -> Session. Choose the Java Desktop System from the list of available desktop environments.
On the login screen, choose Options -> Language.
Choose the language group that includes the language that you want.
Choose a language, then click OK.
Enter your username, then click OK.
Enter your password, then click OK.
Your system administrator sets the default language for your system. The Options menu on the login screen enables you to access other languages. When you choose a language in the Options menu, your system sets the LANG variable for your session. The system restores the default language at the end of the session.
