The following table describes the typographic conventions used in this book.
Table P–2 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 | The names of commands, files, and directories: onscreen computer output |
Use ls -a to list all files. Edit your .login file. machine_name% you have mail. |
AaBbCc123 | What you type, contrasted with onscreen computer output |
machine_name% su Password: |
AaBbCc123 | Command-line placeholder: replace with a real name or value |
To delete a file, type rm filename. |
AaBbCc123 |
Book titles, new words, or terms, or words to be emphasized |
Read Chapter 6 in User's Guide. These are called class options. You must be the root user to do this. |
