This chapter describes the Help system in the Java Desktop System.
The source documents for the online Help in the Java Desktop System are XML files. The XML files are written to the DocBook XML Version 4.1.2 document type definition (DTD). The DocBook XML files are converted to HTML, and the HTML is displayed in the Help browser. For more information about DocBook XML, see the following URL:
http://www.oasis-open.org/docbook/xml
The Java Desktop System can display Help in the following Help browsers:
JDSHelp
Yelp
The JDSHelp browser is based on the Javahelp browser. For more information about Javahelp file formats, how to write documents for Javahelp, and how to group documents in hierarchies, see the following
URL:
http://java.sun.com/products/javahelp/reference/docs/index.html
The Yelp browser uses Open Source
Metadata Framework (OMF) files, and a cataloging system.
The XML file for each manual has an associated OMF file. The OMF file
contains information about the manual that is used by the Yelp browser. OMF files have a .omf extension.
When you install an application, the installation process installs an
OMF file to a directory of OMF files. If a Help document has an associated
OMF file in an OMF file directory, users can access the Help document from
the Yelp browser.
OMF files contain information about Help documents such as the following:
The location of the XML file for the Help document
The title of the Help document
A subject category to which the Help document belongs
