A session occurs between the time that a user logs in to the desktop and the time that the user logs out. The session manager starts after the login manager authenticates the user. The session manager enables the user to manage the session. For example, a user can save the state of a session and return to that session the next time that the user logs in.
At a minimum, the following applications run in a session:
The session manager, gnome-session.
The GConf X settings daemon, gnome-settings-daemon.
The gnome-panel application, which
runs the panels on the desktop.
The Metacity window manager.
The Nautilus file manager.
The gnome-keyring daemon.
If magicdev, the CD Device Options preference tool, is present on the system,
this preference tool is also run in the session.
