The On-Screen Keyboard
application displays virtual keyboards on your desktop. You can use the standard
mouse pointer or alternative pointing device to operate the virtual keyboards. On-Screen Keyboard displays the following types of keyboards:
Compose keyboards that enable you to compose text. To type alphanumeric characters, you select the characters on the compose keyboard.
Dynamic keyboards that On-Screen Keyboard
generates to reflect the applications that are currently running on the desktop.
For example, On-Screen Keyboard generates keyboards
that contain keys to represent the applications that are running on your desktop
or the menus that are contained in an application.
To start On-Screen Keyboard, click Launch, then choose Applications -> Accessibility -> On-Screen
Keyboard. For more information about the On-Screen Keyboard application, see the online Help for On-Screen Keyboard.
If you are an On-Screen Keyboard
user, you cannot use any application in Full Screen mode because the application
window obscures the On-Screen Keyboard display.
To resize the window for use with the On-Screen Keyboard application, perform the following steps:
Do not enable the Full Screen mode in the application.
Give focus to the application window.
Press F10 to maximize the application.
