Before you use On-Screen
Keyboard or Screen Reader and Magnifier,
you must disable the screensaver. To disable the screensaver, perform the
following steps:
Click Launch, then choose Preferences -> Desktop Preferences -> Display -> Screensaver.
In the Display Modes tabbed section, deselect the Lock Screen After check box.
In the Mode drop-down list, select Disable Screen Saver.
Choose File -> Restart Daemon.
Choose File -> Quit to close the Screensaver Preferences dialog.
