Java Desktop System Release 3 Accessibility Guide
Chapter 2 Configuring the Mouse and Keyboard
This chapter describes how to configure the mouse and keyboard to make these devices accessible to more users.
2.1 Configuring the Mouse
Use the Mouse preference tool to configure the mouse to suit your needs. To open the Mouse preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Mouse. The Mouse Preferences dialog is displayed.
2.1.1 To Configure the Behavior of the Mouse
The following sections describe how to modify the behavior of the mouse to suit your needs.
2.1.1.1 To Configure the Mouse for Left-Handed Use
To configure the mouse for left-handed use, click on the Buttons tab in the Mouse Preferences dialog, then select the Left-handed mouse option. When you select this option, the system swaps the functions of the left mouse button and the right mouse button immediately.
2.1.1.2 To Configure the Double-Click Behavior
If you have difficulty double-clicking, you can increase the period of time that the system allows to elapse between the first click and the second click of a double-click. For example, if the double-click timeout setting is 0.4 seconds, you must perform the second click of a double-click within 0.4 seconds of the first click. If the second click occurs more than 0.4 seconds after the first click, the system interprets the two clicks as two single clicks.
To configure the double-click timeout setting, perform the following steps:
  1. Click on the Buttons tab in the Mouse Preferences dialog.
  2. Use the Timeout slider to specify the timeout in seconds that the system allows between the two clicks of a double-click.
  3. Double-click on the light bulb to the right of the slider to test the setting. If you perform the two clicks of the double-click within the timeout specified, the light bulb lights up fully to display a yellow glow around the bulb. If you do not double-click within the timeout specified, the light bulb does not light fully. You should increase the timeout setting and try again. When the light bulb lights, the timeout setting is suitable for your needs.
2.1.1.3 To Change the Size of the Cursor and Pointer
To change the size of the cursor and pointer that is displayed on the desktop, perform the following steps:
  1. Click on the Cursors tab in the Mouse Preferences dialog.
  2. Select one of the following Cursor Size options:
    • Small
    • Medium
    • Large
  3. To complete this change, you must log out of your session and log in again.
2.1.1.4 To Locate the Mouse Pointer
If you have difficulty locating the mouse pointer on the screen, you can enable an option to highlight the pointer when you press the Control key. To enable this option, click on the Cursors tab in the Mouse Preferences dialog, then select the Highlight the pointer when you press Ctrl option. When you press Control, the system displays an animation around the pointer to highlight the pointer.
Note –
On some platforms, you must log out and log in again before this setting takes effect.
2.1.1.5 To Configure the Speed and Sensitivity of the Mouse
To configure the speed and sensitivity of the mouse, perform the following steps:
  1. Click on the Motion tab in the Mouse Preferences dialog.
  2. Configure the following options:
    Acceleration
    Use the slider to specify the speed at which the mouse pointer moves around the screen when you move your mouse.
    If you select a low setting, the mouse pointer moves at a speed similar to the speed at which you are physically moving the mouse. This means that you need to physically move the mouse larger distances to cover the screen area. If you select a high setting, the mouse pointer moves at a faster speed than the speed at which you physically move the mouse. This means that you need to physically move the mouse small distances to cover the screen area.
    Sensitivity
    Use the slider to specify how sensitive the mouse pointer is to movements of your mouse.
    Threshold
    Use the slider to specify the distance that you must move an item before the system interprets the move action as a drag-and-drop action.
2.1.2 To Configure the Cursor
The following section describes how to modify the display characteristics of the cursor.
2.1.2.1 To Stop the Cursor Blinking
To stop the cursor blinking in text boxes and fields, perform the following steps:
  1. Click Launch, then choose Preferences -> Desktop Preferences -> Keyboard -> Behavior to start the Keyboard Behavior preference tool.
  2. In the Keyboard tabbed section, deselect the Cursor blinks in text boxes and fields option.
2.1.3 To Use the Keyboard to Emulate the Mouse
If you have difficulty using a mouse, you can use the keyboard to emulate the mouse functions. See 2.2.2 To Enable the Keyboard to Emulate the Mouse of this guide for more information.
2.2 Configuring the Keyboard
Use the Keyboard Accessibility preference tool, also known as AccessX, to configure the keyboard accessibility options. To start AccessX, click Launch, then choose Preferences -> Accessibility -> Keyboard.
Note –
Before you can use the Keyboard Accessibility preference tool on Solaris systems, you must follow the steps outlined in A.3 Enabling XKB on Solaris Systems of this guide.
The Keyboard Accessibility Preferences (AccessX) dialog enables you to customize your keyboard in the following ways:
2.2.1 To Activate the Keyboard Accessibility Options
To activate the keyboard accessibility options, perform the following steps:
  1. Click Launch, then choose Preferences -> Accessibility -> Keyboard.
  2. Select the Enable keyboard accessibility features option.
  3. Click on the Basic tab.
  4. Select the Beep when features turned on or off from keyboard option to receive an audible notification each time a user enables or disables a keyboard accessibility option using the following keyboard shortcuts:
    • Press-and-hold Shift for eight seconds to enable or disable the slow keys feature.
    • Press Shift five times to enable or disable the sticky keys feature.
  5. To automatically disable the keyboard accessibility options if the options are not used for a specified number of seconds, select the Disable if unused for X seconds option. Use the slider to specify the number of seconds of keyboard idle time required before the system disables the keyboard accessibility options.
    This option is intended for computers that are shared by a number of different users, some of whom require the keyboard accessibility options.
  6. If you are a Linux user, log out and log in again before the accessibility settings take effect.
The mouse keys feature enables you to use the numeric keypad on the keyboard to emulate mouse actions. This feature benefits users who have difficulty using a mouse or other pointing device. To enable and configure the mouse keys feature, perform the following steps:
  2. Click on the Mouse Keys tab.
  3. Select the Enable Mouse Keys option.
  4. Configure the following options to determine the behavior of the mouse pointer when you control the pointer from the numeric keypad:
    Maximum pointer speed
    Use this spin box to specify the maximum speed, in pixels per second, at which the pointer moves around the screen.
    Time to accelerate to maximum speed
    Use this spin box to specify the duration, in milliseconds, before the pointer accelerates to the maximum pointer speed.
    Delay between keypress and pointer movement
    Use this spin box to specify the interval, in milliseconds, between a keypress and the time when the pointer starts to move.
When you enable mouse keys, the keys on the numeric keypad have the following functions:
Table 2–1 Numeric Keypad to Mouse Function Mapping on Solaris Systems
Numeric Keypad Keys
Function
1, 2, 3, 4, 6, 7, 8, 9
Move the mouse pointer around the screen
5
Mouse button click
0
Mouse button double-click
Mouse button press
Mouse button 1
Mouse button 2
Mouse button 3
Table 2–2 Numeric Keypad to Mouse Function Mapping on Linux Systems
Numeric Keypad Keys
Function
5
Mouse button click
0
Mouse button 3
Some Solaris systems also use the function keys to emulate the mouse buttons. The common function key to mouse button mappings are described in the following table.
Table 2–3 Function Key to Mouse Function Mapping on Solaris Systems
Function Key
Function
F2
Mouse button 1
F3
Mouse button 2
F4
Mouse button 3
2.2.3 To Enable the Slow Keys Feature
The slow keys feature enables you to customize how the keyboard handles user input in the following ways:
To enable and configure the slow keys feature, perform the following steps:
  2. Click on the Filters tab.
  3. Select the Enable Slow Keys option.
    Tip –
    To select or deselect the slow keys feature from the keyboard, press-and-hold Shift for eight seconds. The Shift keyboard shortcut automatically selects all of the slow keys options. If you selected the Beep when features turned on or off from the keyboard option, after four seconds the system beeps three times to indicate that the system is about to select or deselect the feature. If you enable this feature from the keyboard, you must press-and-hold Shift for eight seconds again to disable the feature.
  4. Use the Only accept keys held for slider or spin box to specify the duration, in milliseconds, for which you must press-and-hold a key before the system accepts the keypress. Use the Type to test settings text box to test the slow keys setting and modify the setting as required.
  5. To enable audible indications of keyboard input and acceptance, select the following options:
    Beep when key is pressed
    Select this option to hear a beep when you press a key.
    Beep when key is accepted
    Select this option to hear a beep when the system accepts a keypress.
    Beep when key is rejected
    Select this option to hear a beep when the system rejects a keypress. The system rejects a keypress if you do not press-and-hold the key for the duration that is specified in the Only accept keys held for spin box.
2.2.4 To Enable the Bounce Keys Feature
The bounce keys feature enables you to customize the keyboard to ignore rapid, repeated keypresses of the same key. For example, users with impaired motor skills might press the same key several times when they intend to press the key once. This feature enables you to customize the keyboard to ignore repeated keypresses.
To enable and configure the bounce keys feature, perform the following steps:
  3. Select the Enable Bounce Keys option.
  4. Use the Ignore duplicate keypresses within slider or spin box to specify the duration in milliseconds (ms) after the first keypress for which the system ignores repeated keypresses of the same key. For example, if you select a duration of 500 ms, the system ignores all repeated keypresses of the same key that occur within 500 ms of the first keypress.
  5. Select the Beep if key is rejected option to hear an audible indication when the system ignores a key.
Note –
If you want to enable the bounce keys feature, ensure that the Enable Slow Keys option is deselected. The slow keys feature requires you to press a key for a specified duration before the system accepts the keypress as a valid keypress. If you cannot press the key for the duration that is specified by the slow keys setting, deselect the Enable Slow Keys option to enable the system to accept your input.
2.2.5 To Enable the Sticky Keys Feature
The sticky keys feature enables you to press the keys in a key combination in sequence rather than simultaneously. This feature is designed for users who are unable to press two or more keys simultaneously.
To enable and configure the sticky keys feature, perform the following steps:
  2. Click on the Basic tab.
  3. Select the Enable Sticky Keys option.
    Tip –
    To enable the sticky keys feature from the keyboard, press Shift five times. The Shift keyboard shortcut automatically selects all of the sticky keys options. If you selected the Beep when features turned on or off from the keyboard option, the system beeps to indicate that the system is about to select or deselect the feature. If you enable this feature from the keyboard, press Shift five times again to disable the feature.
  4. Select the Beep when modifier is pressed option to receive an audible indication each time you press a modifier key such as Ctrl, Alt, or Shift. This option is useful to remind you whether a modifier key is active or inactive.
  5. To automatically disable the sticky keys feature when you press two keys simultaneously, select the Disable if two keys pressed together option.
You can use the sticky keys feature in latch or lock mode. The following table describes how to choose a mode and the difference between the two modes.
Table 2–4 Sticky Keys Latch or Lock Mode
To use the sticky keys feature in...
Press the modifier key...
The modifier key remains active until...
Latch mode
Once.
You press a non-modifier key.
Lock mode
Twice in quick succession.
You press the modifier key again.
Example 1: If you want to press Alt + F1, do the following:
  1. Press Alt to latch the modifier key. The Alt key remains active.
  2. Press F1. The key combination is now complete. After you press F1, the Alt modifier key is no longer active.
Example 2: If you want to press Ctrl + Alt + Tab, do the following:
  1. Press Ctrl twice to lock the modifier key. The Ctrl key remains active.
  2. Press Alt.
  3. Press Tab. The key combination is now complete.
  4. To unlock the modifier key, press Ctrl again.
2.2.6 To Enable Audible Notifications for Toggle Keys
A toggle key is any key on the keyboard that can switch between two states. The Num Lock, Caps Lock, and Scroll Lock keys are toggle keys. Most toggle keys have an associated light emitting diode (LED) on the keyboard that lights when the toggle key is active. To assist users with visual impairments, you can customize the keyboard to emit an audible notification when a user presses a toggle key. For example, when you press Num Lock, you can determine whether the key is toggled or not toggled by the sound that the keyboard emits.
To enable accessible toggle keys, perform the following steps:
  3. Select the Enable Toggle Keys option.
When you activate the Num Lock, Caps Lock, or Scroll Lock keys, the system beeps once. When you deactivate a toggle key, the system beeps twice.
2.2.7 To Enable the Repeat Keys Feature
The repeat keys feature enables you to repeat a keystroke multiple times without pressing the key more than once. This feature is designed for users who cannot release keys quickly, for example users who operate a mouth stick. When you enable repeat keys, you can specify the duration for which you must press a key before the key starts to repeat.
To enable and configure the repeat keys feature, perform the following steps:
  3. Select the Enable Repeat Keys option.
  4. Use the Delay slider or spin box to specify the duration for which you must press a key before the keyboard interprets the action as a repeat key. If you have difficulty releasing keys, select a long time delay.
  5. Use the Speed slider or spin box to specify the speed at which the keyboard repeats the keypress as input.
2.3 Using the Keyboard Accessibility Status Panel Application
The Keyboard Accessibility Status panel application shows you the status of the keyboard accessibility features. This panel application displays icons to indicate which keyboard accessibility features are enabled in the Keyboard Accessibility preference tool.
To add the Keyboard Accessibility Status panel application to a panel, right-click on the panel, then choose Add to Panel -> Accessories -> Keyboard Accessibility Status.
The following table describes the icons that the panel application displays and the status that each icon represents.
Table 2–5 Keyboard Accessibility Status Icons
Icon
Keyboard Accessibility Features enabled icon
Keyboard accessibility in general is enabled but none of the individual key features are enabled.
Bounce keys enabled icon
The bounce keys feature is enabled.
Mouse keys enabled icon
The mouse keys feature is enabled.
Slow keys enabled icon
The slow keys feature is enabled.
Alt key latched icon
The sticky keys feature is enabled and the Alt key is latched.
Alt key locked icon
The sticky keys feature is enabled and the Alt key is locked.
Ctrl key latched icon
The sticky keys feature is enabled and the Ctrl key is latched.
Ctrl key locked icon
The sticky keys feature is enabled and the Ctrl key is locked.
Shift key latched icon
The sticky keys feature is enabled and the Shift key is latched.
Shift key locked icon
The sticky keys feature is enabled and the Shift key is locked.
Super/Windows key latched icon
The sticky keys feature is enabled and the Super/Windows key is latched.
Super/Windows key locked icon
The sticky keys feature is enabled and the Super/Windows key is locked.
