The sticky keys feature enables you to press the keys in a key combination in sequence rather than simultaneously. This feature is designed for users who are unable to press two or more keys simultaneously.
To enable and configure the sticky keys feature, perform the following steps:
Click Launch, then choose Preferences -> Accessibility -> Keyboard.
Click on the Basic tab.
Select the Enable Sticky Keys option.
To enable the sticky keys feature from the keyboard, press Shift five times. The Shift keyboard shortcut automatically selects all of the sticky keys options. If you selected the Beep when features turned on or off from the keyboard option, the system beeps to indicate that the system is about to select or deselect the feature. If you enable this feature from the keyboard, press Shift five times again to disable the feature.
Select the Beep when modifier is pressed option to receive an audible indication each time you press a modifier key such as Ctrl, Alt, or Shift. This option is useful to remind you whether a modifier key is active or inactive.
To automatically disable the sticky keys feature when you press two keys simultaneously, select the Disable if two keys pressed together option.
You can use the sticky keys feature in latch or lock mode. The following table describes how to choose a mode and the difference between the two modes.
Table 2–4 Sticky Keys Latch or Lock Mode|
To use the sticky keys feature in... |
Press the modifier key... |
The modifier key remains active until... |
Latch mode |
Once. |
You press a non-modifier key. |
Lock mode |
Twice in quick succession. |
You press the modifier key again. |
Example 1: If you want to press Alt + F1, do the following:
Press Alt to latch the modifier key. The Alt key remains active.
Press F1. The key combination is now complete. After you press F1, the Alt modifier key is no longer active.
Example 2: If you want to press Ctrl + Alt + Tab, do the following:
Press Ctrl twice to lock the modifier key. The Ctrl key remains active.
Press Alt.
Press Tab. The key combination is now complete.
To unlock the modifier key, press Ctrl again.
