The Keyboard Accessibility Status
panel application shows you the status of the keyboard accessibility features.
This panel application displays icons to indicate which keyboard accessibility
features are enabled in the Keyboard Accessibility
preference tool.
To add the Keyboard Accessibility Status
panel application to a panel, right-click on the panel, then choose Add to Panel -> Accessories -> Keyboard Accessibility Status.
The following table describes the icons that the panel application displays and the status that each icon represents.
Table 2–5 Keyboard Accessibility Status Icons|
Icon |
Keyboard Accessibility Status |
Keyboard accessibility in general is enabled but none of the individual key features are enabled. |
The bounce keys feature is enabled. |
The mouse keys feature is enabled. |
The slow keys feature is enabled. |
The sticky keys feature is enabled and the Alt key is latched. |
The sticky keys feature is enabled and the Alt key is locked. |
The sticky keys feature is enabled and the Ctrl key is latched. |
The sticky keys feature is enabled and the Ctrl key is locked. |
The sticky keys feature is enabled and the Shift key is latched. |
The sticky keys feature is enabled and the Shift key is locked. |
The sticky keys feature is enabled and the Super/Windows key is latched. |
The sticky keys feature is enabled and the Super/Windows key is locked. |
