Before you can use or modify a window, you must give focus to the window. The following table lists the keyboard shortcuts that you can use to give focus to a window.
Keys |
Function |
Alt + Tab |
Display a popup window with icons that represent each window. Press-and-hold Alt and continue to press Tab to move through the windows until you reach the window to which you want to give focus. |
Alt + Esc |
Raise each window in turn until you reach the window to which you want to give focus. |
