3.9.7 To Navigate Drop-Down Lists
A drop-down list is a control that you use to
select one of several available items. The drop-down list contains a button
that you use to display the available items.
Figure 3–6 Sample Drop-Down List
The following table lists the keyboard shortcuts that you can use to
navigate a drop-down list.
Keys
Function
spacebar
This key performs one of the following functions:
If the drop-down list is not open, this key opens the drop-down
list.
If the drop-down list is open, this key accepts the current
selection and closes the list.
up arrow
Select the previous list item.
down arrow
Select the next list item.
Esc
Close the list without changing
the selection.
